title: "system.dataset.dataSetToHTML"
description: "Formats the contents of a dataset as an HTML page, returning the results as a string."
# system.dataset.dataSetToHTML
This function is used in **Python Scripting**.
## Description
Formats the contents of a [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) as an HTML page, returning the results as a string. Uses the `
` element to create a data table page.
## Client Permission Restrictions
This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions.
## Syntax
`system.dataset.dataSetToHTML(showHeaders, dataset, title)`
### Parameters
Type | Parameter | Description
Boolean| `showHeaders` | If true, the HTML table will include a header row.
Dataset| `dataset` | The dataset to export.
String |`title` | The title for the HTML page.
### Returns
**String** - The HTML page as a string.
### Scope
## Example Output
Expand the panel below to see an example of the resulting HTML this function returns.
Table Data
Table Data
| Col 1 |
Col 2 |
Col 3 |
| 58 |
Test Row 3 |
27.524042612227795 |
| 87 |
Test Row 10 |
43.48674729787205 |
| 29 |
Test Row 15 |
82.46334440414927 |
| 3 |
Test Row 120 |
15.07317567946509 |
## Code Examples
```python title="Code Snippet"
# Get dataset from a Table component
dataset = event.source.parent.getComponent('Table').data
# Format dataset as HTML string
showHeaders = True
title = "Table Data"
html = system.dataset.dataSetToHTML(showHeaders, dataset, title)
# Choose filepath for output
filePath = "C:\\output\\results.html"
# Write the HTML to a file
system.file.writeFile(filePath, html)
# This snippet would run a SQL query against a database, and turn the results into a string containing HTML. It then writes the string to a file on the local hard drive.
results = system.db.runNamedQuery("Fetch Records",{})
html = system.dataset.dataSetToHTML(1, results, "Production Report")
