--- title: "Vision - The Window Object Scripting Functions" --- # Vision - The Window Object Scripting Functions > This page details the various component and extension functions available for [Vision's Window Object components](vision-window-object.md). ## Component Functions ### .getRootContainer * Description * Returns a reference to the Root Container in the window. * Parameters * None * Return * Object - a reference to the Root Container, which is functionally just a [Vision - Container](../containers/container.md). ### .getComponentForPath * Description * Returns a reference to a component. The path parameter allows you to specify the full path to the component as a string. * Parameters * String **path** - The path to the component, using a period as a delimiter, such as "Root Container.Group.Label". * Return * Object - to the component specified, or None if there is a typo in the path. ## Extension Functions This component does not have extension functions associated with it.
