--- title: "How To Restrict Acknowledgement on the Vision Alarm Status Table Component" --- # How To Restrict Acknowledgement on the Vision Alarm Status Table Component > In order for operators to acknowledge alarms, the correct permission must be assigned. This example shows how to set permissions to acknowledge alarms for users in the **Operator** role. You can setup permissions for any role, user and user source in your system. ## Security for Alarm Acknowledgement If you want to restrict who can use the Acknowledge button, there is the **Show Ack Button** in the Property Editor that can be set to '**False**.' By setting the **Show Ack Button** to '**false**,' this hides the Acknowledge button on the Alarm Status Table. 1. Select the Alarm Status Table component, and click the **Show Ack Button** binding ![](../binding.png) icon to open the Property Binding window. 1. Under **Property Binding Type**, select **Expression**. 1. Click the **Function** ![](../function.png) icon and scroll down to **Users**, and select '**hasRole**.' This enters the function name. 1. Edit the expression to read: **hasRole("Operator")** 1. Click **OK**. If you currently have the "Operator" role you will notice that the **Show Ack Button** property is now '**true**,' otherwise, it will be '**false**.' ![](how-to-restrict-acknowledgement.png)
