--- title: "Perspective - View Object" --- # Perspective - View Object > This is the view itself. A view has properties that control the view size, defines how tags are dropped into a view, and settings for loading client views. The view properties are the same for each container type. View properties are displayed in the Perspective Property Editor when you click on the view in the Project Browser. ![](2021-03-22_16-45-27.png) ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules\perspective\working-with-perspective-components\bindings-in-perspective\bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules\perspective\working-with-perspective-components\perspective-component-properties.md) page. | Name | Description | Property Type | | ---------------|------------| ------------- | | defaultSize | Default size of the container.**width**: Width of the view. Default is 800px. Value is numeric.**height**: Height of the view. Default is 800px. Value is numeric. | value: numeric| | dropConfig | Provides an opportunity to automatically create an instance of this view via tag drop. Click to see [dropConfig](#dropconfig-properties) properties. See the [Drop Configuration](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/tag-bindings-in-perspective/drop-configuration.md) page for more information. | object | | loading | Options for loading the view.**mode**: Provides two options for loading views, particularly for views with a high number of components: blocking and non-blocking. Blocking loads faster for views with fewer components. Non-blocking loads views with a large number of components in chunks. Default is 'non-blocking'.Views set to non-blocking will only wait patiently for five seconds if they have not been called. Value is string. | object | | inputBehavior | Controls whether the internal properties of object-typed input and bi-directional parameters are merged with existing default values or whether the object-typed parameter should be strictly replaced with the supplied values.If "replace" is selected, and an object-typed parameter is supplied which does not contain a key for a default value, then that default value will not be used. Default is replace. [Examples](#inputbehavior-examples) are included below.|object| ### dropConfig Properties | Name | Description | Property Type | | --------- | ------------- | ------------- | | udts | These settings allow for the automatic creation of this view when a UDT instance is dragged onto another view, using \_this\_ view to represent the UDT. A parameter is passed into the view, allowing the view to reference the UDT.**type**: The name of the UDT to associate with this view. Value is string.**param**: Name of the parameter on this view that the UDT member values will be passed to. Value is string.**action**: Value is boolean.**bind**: Automatically configures a tag binding on the parameter (specified by **param**) to the UDT.**path**: Passes in a tag path string on the parameter (specified by **param**)|object| | dataTypes | These settings allow for the automatic creation of this view when a standard tag is dragged onto another view. A parameter is passed into the view, allowing the view to reference the tag.**type**: The tag data type to associate with this view. Value is string.**param**: Name of the parameter to pass into this view. Value is string.**action**: Value is boolean.**bind**: Automatically configures a tag binding on the parameter (specified by **param**) to the tag.**path**: Passes in a tag path string on the parameter (specified by **param**)|object| ### inputBehavior Examples Defined “default” parameter: ``` myObject: { myParamOne: "One", myParamTwo: "Two" } ``` Supplied parameter from Embedding Component: ``` myObject: { myParamOne: "1", myParamThree: "3" } ``` If “merge” is selected: ``` myObject: { myParamOne: "1", myParamTwo: "Two", myParamThree: "3" } ``` If “replace” is selected: ``` myObject: { myParamOne: "1", myParamThree: "3" } ``` Note that there is no value for myParamTwo, so any references to this property will fault. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component.
