Version: 8.1
Perspective - Link
Component Palette Icon:
The Link component allows users to create a hyperlink that points to a destination such as a page, view, resource, or mount path that they can quickly navigate to. Links are easily identifiable because they typically have a different color font then the rest of the content, and an underscore when you hover over them. To configure a link, enter the URL for the destination, and the name of the link in the 'text' property.
Properties​
NameDescriptionProperty Type
urlA URL, URL fragment, or a Page URL given to a Page. If the target is a Page, its Page URL can be found in the Page Configuration settings of the project. See Page URLs.value: string
textText to display in the link.value: string
targetSpecifies where to display the linked URL. Options are:
  • self for the current tab/context
  • tab or 'blank' for a new tab
  • parent for the parent frame tab/context
  • top for the full body of the window
Otherwise, supports standard w3c values for anchor link target attributes.
value: string
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
