--- title: "Perspective - Signature Pad Scripting" --- # Perspective - Signature Pad Scripting > This page details the various scripting, component, and extension functions available for [Perspective's Signature Pad](perspective-signature-pad.md) component. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ### onSignatureSubmitted Event is fired after the Gateway has received a submitted signature. :::note This component event is designed to be used in tandem with a run action script. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter. ::: #### event.signature * Object Path * event.signature * Type * String * Description * Base64-encoded PNG **DataURL** of the submitted signature. #### event.signatureFile.name * Object Path * event.signatureFile.name * Type * String * Description * A name for the signature file. #### event.signatureFile.size * Object Path * event.signatureFile.size * Type * Integer * Description * The size of the signature image file in bytes. #### event.signatureFile.copyTo(filePath) * Object Path * event.signatureFile.copyTo() * Description * Saves the uploaded signature file at a location accessible to the Gateway. * Parameters * String **filePath** - The path to where the file should be saved on the Gateway. * Return * None #### event.signatureFile.getBytes() * Object Path * event.signatureFile.getBytes() * Description * Returns a bytearray of the image, allowing the signature file to be saved from the session (with system.perspective.download()). * Parameters * None * Return * byteArray - The raw data of the incoming file. #### event.signatureFile.getString() * Object Path * event.file.getString() * Description * Fetches the incoming file data and attempts to parse it as a string via UTF-8 (Eight-bit UCS Transformation Format) encoding. Defaults to UTF-8 (super common), but can use other character sets. Passed as a string, for example getString("UTF_16BE). * Parameters * None * Return * byteArray - The raw data of the incoming signature file. ### onSignatureCleared This event is fired when the Gateway has received a signal that the signature has been cleared. :::note This component event is designed to be used in tandem with a run action script. Within the script action, special properties and methods are available on the **event** object, which is passed to the script action as a parameter. ::: #### event * Object Path * event * Type * Null * Description * An empty event object. ## Component Functions ### .clearSignature() * Description * Clears the current signature on the component * Parameters * None * Return * Nothing ### .submitSignature() * Description * Submits the signature, triggering the onSignatureSubmitted component event. * Parameters * None * Return * Nothing ## Extension Functions This component does not have extension functions associated with it.
