--- title: "Perspective - DateTime Input" description: "A DateTime Input is an easy way to select a date from a popup calendar." --- # Perspective - DateTime Input > A DateTime Input is an easy way to select a date from a popup calendar. ![](img1.png) **Component Palette Icon**: ![](img2.png) ## Description A DateTime Input is an easy way to select a date from a popup calendar. Similar to the DateTime Picker component, it takes up much less real estate on the screen. Configure the date and time format in the Property Editor using the 'formattedValue' property. The DateTime Input component has two pre-configured [variants](../../../../../ignition-modules/perspective/working-with-perspective-components/working-with-perspective-components.md): * Date and Time - Opens a calendar from which users can select a date and time. * Time - Enables users to set a time using the up and down arrows on the component. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | --------------- | --------------- | -------------- | | value | Current date/time as a Date object or timestamp in milliseconds. | value: string | | formattedValue | Date and time in configured format. | value: string | | inputProps | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous.| object | | modalStyle | Style applied to the Date picker modal (popup). Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | pickerType | Whether to display and enable picker for date only, time only, or both date and time. | value: string | | minDate | Minimum date/time as a Date object or timestamp in milliseconds. If null, the minimum date is 10 years in the past from today. | value: string | | maxDate | Maximum date/time as a Date object or timestamp in milliseconds. If null, the maximum date is 10 years in the future from today. | value: string | | format | Template for formatting date display - must be valid moment.js format, e.g., 'MM/DD/YYYY h:mm a'. | value: string | | enabled | 'False' will disable any interaction with the calendar.**Note:** If the component is disabled, scripts can still run on the component. For example, if you add a [script action](../../../../../ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md#script-action) to a System Event, such as an onStartup event, the script will fire when the page is loaded. Events that require user interaction, such as onClick events, will not fire with the exception of Pointer Events. | value: boolean | | placeholder | Text for input field to display when no date/time is selected. | value: boolean | | locale | Code for localization of language and formatting. Use the dropdown to select language. | value: string | | dismissOnSelect | Determines if the date picker should be dismissed when a date is selected. | value: boolean | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](img3.png) |Property|Value|Style Category| |--|--|--| |props.pickerType| date| N/A| |props.format| MM/DD/YYYY| N/A| |props.style.borderStyle| solid| border| |props.style.borderColor| #00AC00 |border| |props.style.borderWidth| 2px| border|
