--- title: "Perspective - Map Scripting" --- # Perspective - Map Scripting > This page details the various scripting, component, and extension functions available for [Perspective's Map](perspective-map.md) component. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right-clicking on the component. ### onMarkerClick Interaction event. Fired when the marker is clicked. Returns the unique name of the marker. |Object Path|Type|Description| |--|--|--| |event.name| String |The name of the marker.| ### onMapClick Interaction event. Fired when the map is clicked. Returns the lat and lng of the mouse click as it translates on the map. |Object Path|Type|Description| |--|--|--| |event.lat |Numeric |The latitude of where on the map the user clicked.| |event.lng |Numeric |The longitude of where on the map the user clicked.| ### onMapMouseMove Interaction event. Fires as the mouse moves over the map. Returns lat and lng of the mouse as it translates on the map. |Object Path|Type|Description| |--|--|--| |event.lat| Numeric |The latitude of where the mouse moved.| |event.lng |Numeric |The longitude of where the mouse moved.| ### onVectorClick Interaction event. Fired when a vector is clicked. Returns the name of the vector, the type of the vector, and the coordinates of the vector. |Object Path|Type|Description| |--|--|--| |event.name| Any| The given name of the vector. Returns an empty string if a name is not defined. | |event.type |String |The type of the vector clicked. Possible values are:- polygon- circle- polyline- rectangle| |event.lat |Numeric| The latitude of the clicked vector.| |event.lng |Numeric| The longitude of the clicked vector.| ### onZoomStart Map state event. Fired when the map zoom is about to change (e.g. before zoom animation). Returns the zoom level. |Object Path|Type|Description| |--|--|--| |event.zoom |Numeric |What the zoom level on the map was before zooming.| ### onZoom Map state event. Fired repeatedly during any change in zoom level, including zoom and fly animations. Returns the zoom level. |Object Path|Type|Description| |--|--|--| |event.zoom |Numeric| What the zoom level was changed to.| ### onZoomEnd Map state event. Fired when the map has changed, after any animations. Returns the zoom level. |Object Path|Type|Description| |--|--|--| |event.zoom| Numeric |What the zoom level on the map was after zooming.| ### onMoveStart Map state event. Fired when the view of the map starts changing (e.g., user starts dragging the map). Returns the map center as lat and lng. |Object Path|Type|Description| |--|--|--| |event.lat| Numeric |The latitude of the center of the map before moving.| |event.lng| Numeric |The longitude value for the center of the map before moving.| ### onMove Map state event. Fires repeatedly during any movement on the map, including pan and fly animations. Returns the map center as lat and lng. |Object Path|Type|Description| |--|--|--| |event.lat| Numeric |The latitude value for the center of the map during moving.| |event.lng |Numeric |The longitude value for the center of the map during moving.| ### onMoveEnd Map state event. Fired when the center of the map stops changing (e.g. user stopped dragging the map). Returns the new map center as lat and lng. |Object Path|Type|Description| |--|--|--| |event.lat |Numeric| The latitude value for the center of the map after moving.| |event.lng| Numeric |The longitude value for the center of the map after moving.| ### onResize Map state event. Fires when the map size has changed. Returns the map size as oldSize and newSize. |Object Path|Type|Description| |--|--|--| |event.oldSize |PyJsonObjectAdapter|Returns the starting size of the map before the resize. Values are returned in an object that's functionally similar to a Python dictionary. The object contains two values: height and width. | |event.newSize |PyJsonObjectAdapter| Returns the starting size of the map after the resize. Values are returned in an object that's functionally similar to a Python dictionary. The object contains two values: height and width. | ## Component Functions ### .getCenter() * Description * Returns the geographical center of the map in latitude and longitude. * Parameters * Nothing * Return * LatLng - Returns the geographical center of the map view as `{"lat": number, "lng": number}`. ### .getZoom() * Description * Returns the current zoom level of the map view as a number. * Parameters * Nothing * Return * Returns the current zoom level of the map view as a number. ### .getBounds() * Description * Returns the geographical bounds of the map as a dictionary. * Parameters * Nothing * Return * Dictionary: A dictionary containing the following keys: `north: number` `northEast: LatLng` `east: number` `southEast: LatLng` `south: number` `southWest: LatLng` `west: number` `northWest: LatLng` ### .getBoundsAsBBoxString() * Description * Returns a string with bounding box coordinates in a 'South West longitude, South West latitude, North East longitude, North East latitude' format. * Parameters * Nothing * Return * Returns the bounding box of the map as a string. ### .zoomIn([delta, options]) * Description * Increases the zoom of the map by delta. * Parameters * Numeric **delta** - The numerical value to increase the zoom by. If omitted, uses the value of props.zoom.delta. [optional] * Dictionary **options** - A dictionary of parameters to use during the zoom, typically containing a single key, animate. See [Perspective - Map ZoomOptions](perspective-map.md#zoomoptions). [optional] * Return * Nothing ### .zoomOut([delta, options]) * Description * Decreases the zoom of the map by delta. * Parameters * Numeric **delta** - The numerical value to decrease the zoom by. If omitted, uses the value of props.zoom.delta. [optional] * Dictionary **options** - A dictionary of parameters to use during the zoom, typically containing a single key, animate. See [Perspective - Map ZoomOptions](perspective-map.md#zoomoptions). [optional] * Return * Nothing ### .setZoomAround(point, zoom, [options]) * Description * Zooms the map while keeping a specified geographical point on the map stationary (e.g. used internally for scroll zoom and double-click zoom) * Parameters * Dictionary **point** - The geographic point that the map will zoom around. See [Perspective - Map LatLng](perspective-map.md#latlng). [required] * Numeric **zoom** - The numerical value to increase the zoom by. If omitted, uses the value of props.zoom.delta. [optional] * Dictionary **options** - A dictionary of parameters to use during the zoom, typically containing a single key, animate. See [Perspective - Map ZoomOptions](perspective-map.md#zoomoptions). [optional] * Return * Nothing ### .fitBounds(latLngBounds, [options]) * Description * Sets a map view that contains the given geographical bounds with the maximum zoom level possible * Parameters * Dictionary **latLngBounds** - A dictionary consisting of two LatLng objects. The LatLng objects combined represent the geographical bounds the map view should be set to. [required] * Dictionary **options** - A dictionary of parameters used to manipulate the FitBound settings. See [Perspective - Map FitBounds](perspective-map.md#fitbounds). [optional] * Return * Nothing ### .fitWorld([options]) * Description * Sets a map view that mostly contains the whole world with the maximum zoom level possible. * Parameters * Dictionary **options** - A dictionary of parameters used to manipulate the FitBound settings. See [Perspective - Map FitBounds](perspective-map.md#fitbounds). [optional] * Return * Nothing ### .panTo(latLng, [options]) * Description * Pans the map to a given center. * Parameters * Dictionary **latLng** - The geographic point to pan to. [required] * Dictionary **options** - A dictionary of parameters used to modify the panning behavior. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .panBy(point, [options]) * Description * Pans the map by a given number of pixels (animated). * Parameters * Dictionary **point** - The geographic point to pan to. The dictionary should contain an 'x' and 'y' key, both with numeric values. [required] * Dictionary **options** - A dictionary of parameters used to modify the panning behavior. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .flyTo(latLng, [zoom, options]) * Description * Sets the view of the map (geographical center and zoom) performing a smooth pan-zoom animation. * Parameters * Dictionary **latLng** - A Python dictionary representing the coordinates to fly to. [required] * Numeric **zoom** - Sets the zoom level to transition to during the flight. If omitted, uses the value of props.zoom.delta. [optional] * Dictionary **options** - A dictionary of panning options to use. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .flyToBounds(latLngBounds, [options]) * Description * Sets the view of the map with a smooth animation like flyTo, but takes a bounds parameter like FitBounds. * Parameters * Dictionary **latLngBounds** - A dictionary consisting of two LatLng objects. The LatLng objects combined represent the geographical bounds the map view should be set to. [required] * Dictionary **options** - A dictionary of panning options to use. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .panInsideBounds(latLngBounds, [options]) * Description * Pans the map to the closest view that would lie inside the given bounds (if it's not already), controlling the animation using the options specific, if any. * Parameters * Dictionary **latLngBounds** - A dictionary consisting of two LatLng objects. The LatLng objects combined represent the geographical bounds the map view should be set to. [required] * Dictionary **options** - A dictionary of panning options to use. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .panInside(latLng, [options]) * Description * Pans the map the minimum amount to make the latLng visible. * Parameters * Dictionary **latLng** - A Python dictionary representing the coordinates to pan to. [required] * Dictionary **options** - A dictionary of panning options to use. See [Perspective - Map PanOptions](perspective-map.md#panoptions). [optional] * Return * Nothing ### .getSize() * Description * Returns height and width of the Map component. * Parameters * Nothing * Return * JSON Object - Returns a Python dictionary. Contains two items: height and width. ### Scripting Example ``` def doMapStuff(self): map = self.getSibling("Map") coordinateBounds = {'corner1': {'lat': 39.086798, 'lng': -120.069014}, 'corner2': { 'lat': 38.815319, 'lng': -119.787519 }} latLngTahoe = {'lat': 39.086798, 'lng': -120.069014 } latLngInductive = {'lat': 38.652511, 'lng': -121.189438 } zoomPanOptions = { 'animate': True, 'duration': 3, 'easeLinearity': 0.25, 'noMoveStart': False } fitBoundsOptions = { 'padding': { 'x': 100, 'y': 100 }, 'animate': True, 'duration': 3 } panPixels = { 'x': 200, 'y': 200 } print map.getCenter() # Returns the geographical bounds visible in the current map view as latLngBounds map.flyTo(latLng = latLngTahoe, options = zoomPanOptions) # Sets the view of the map with a smooth animation like flyTo, but takes a bounds parameter like FitBounds ``` ## Extension Functions This component does not have extension functions associated with it.
