--- title: "Perspective - Alarm Status Table" description: "The Alarm Status Table allows you to view currently active alarm events in the system" --- # Perspective - Alarm Status Table > The Alarm Status Table allows you to view currently active alarm events in the system ![](2020-02-11_15-39-06.png) **Component Palette Icon**: ![](2019-07-16_13-01-09.png) ## Description The Alarm Status Table allows you to view currently active alarm events in the system, providing an easy way to inspect the alarm details, shelve alarms, and acknowledge them. Acknowledgement is handled by selecting (checking) alarms and pressing the **Acknowledge** button. Shelving is supported by pressing the **Shelve** button when an alarm is selected and choosing a time duration. You can change the columns that are displayed and the column width in Preview Mode and in a Perspective Session. Right-click on the table header to show/hide columns. Click and drag the margins of the columns to resize their width. You can also sort table columns in ascending or descending order by simply clicking the up or down arrows next to each column header. Sorting on alarm State and Priority in the Alarm Status Table sorts in descending order. All the other columns the sort order is alphanumerical. Columns can be reordered in Preview Mode and in a Perspective Session by clicking and dragging when the dragOrderable property is enabled. ![](java_b0KXi5UcvQ.gif) The Alarm Status Table utilizes a shared polling engine to cache and share polling tasks across concurrent sessions. The cache persists for a period of time that matches the configured poll rate. This optimization allows multiple components to poll the alarm system with a reduced impact on overall performance. ## User Interface ![](2020-01-28_12-17-13.png) |Interation|Description| |--|--| |Active Alarm Events| Shows the number of active alarms in the system. When viewing the shelved alarms view, clicking on the bell icon will switch the component back to the realtime view. | |Config Settings|Clicking the ![](../perspective-alarm-journal-table/2020-01-14_12-56-45.png) icon or right clicking on a column heading will open the Configuration menu, which determines which columns show appear on the component. | |Filters|Clicking the ![](../perspective-alarm-journal-table/2020-01-14_12-57-29.png) icon opens the Filters menu, allowing you to select event states and priorities to filter on. | |Pages |A listing of pages. Long lists of alarm events are spread across multiple pages to improve performance. Clicking on a number will switch which page is shown.| |Popup Modal| Hovering over a row in the table will cause the Popup Modal ![](image.png) icon to appear. Clicking this icon shows more information about the alarm.| |Rows to Display| Determines how many rows are shown per page. | |Search |Clicking the ![](../perspective-alarm-journal-table/2020-01-14_12-58-54.png) icon cause a search bar to appear, allowing the user to type in search terms. | |Shelved Alarms|Shows the number of shelved alarms. When viewing the realtime view, clicking on the Shelved Alarms display will switch to the shelved alarms view. While the table is showing shelved alarms, shelved alarms can be selected from the table and unshelved. ![](17-05-21-14-32-04.png)| In addition, selecting a row within the table shows some additional interaction options. ![](17-05-21-14-10-53.png) The **Shelve** button allows you to shelve the selected alarms. The **Acknowledge** button allows you to mark the selected alarms as "acknowledged". ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. |Name|Description|Property Type| |--|--|--| |refreshRate| The rate at which the table will poll for updates in milliseconds. |value: numeric| |enableHeader|Enable table header. Default is true. |value: boolean| |enableDetails| Enable active events table details action. Default is true. |value: boolean| |enableAcknowledge |Enable acknowledge action. Default is true.|value: boolean| |enableShelve| Enable shelve action. Default is true.|value: boolean| |enableUnshelve| Enable unshelve action. Default is true.|value: boolean |toolbar| Settings for the toolbar. Click to see [toolbar](perspective-alarm-status-table.md#toolbar-properties) properties.|object| |shelvingTimes| Available alarming shelving times in seconds. Shelving times are customizable by editing values for this property in the Property Editor. |array| |responsive|Responsive layout configuration. Rows are converted to cards. While in responsive layout, disables or removes certain table features that are no longer applicable.**enabled**: Enables responsive layout. Default is false. Value is boolean**breakpoint**: Width in pixels that triggers change in responsive layout. Value is numeric.|object| |filters| This is where you configure filtering properties for displaying alarm data in the Alarm Status Table. Click to see the [filter](perspective-alarm-status-table.md#filter-properties) properties.|object| |selection | Currently selected alarms and alarm selection configuration. **active**: Active alarm selection configuration and read-only list of currently selected active alarms. **mode**: Active alarm selection configuration. Options are multiple, single, or none. Value is string. **data**: A read-only list of currently selected active alarms. Value is array. **shelved**: Shelved alarm configuration and read-only list of currently selected shelved alarms. **mode**: Shelved alarm selection configuration. Options are multiple, single, or none. Value is string **data**: A read-only list of currently selected active alarms. Value is array. |object| |rowStyles | Styles to apply to rows given their alarm state and designated priority. Click to see the [rowStyles](perspective-alarm-status-table.md#rowstyles-properties) properties.|object| |activeSortOrder| The default weighted order in which columns and their contents are sorted relative to other columns and their contents. Used when the component loads. Active event columns need to have sort configured in order for this to work. |array| |shelvedSortOrder| The default weighted order in which columns and their contents are sorted relative to other columns and their contents. Used when the component loads. Shelved event columns need to have sort configured in order for this to work.|array| |dragOrderable| When enabled, users may drag column headers to reorder columns in the table.|value: boolean| |columns| Used only for determining what columns to show on load. Click to see [columns](perspective-alarm-status-table.md#columns-properties) properties|object| |columnsAssociated| A list of columns used to retrieve and display alarm associated data. Click to see [columnAssociated](perspective-alarm-status-table.md#columnsassociated-active-properties) properties|object| |pager|Settings for the pager. Click to see [pager](perspective-alarm-status-table.md#pager-properties) properties|object| | style | Sets a style that applies to the component. The [Style menu](appendix/reference-pages/style-reference.md) contains all the tools for modifying text, background, margins, and borders. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | ### toolbar Properties | Name | Description | Property Type | | ------------------- | ------------------ | -------------- | | enabled | Enables the visibility of the table toolbar. Default is true. | value: boolean | | enableActiveTab | Enables the visibility of the Active Events tab. | value: boolean | | enableShelvedTab | Enables the visibility of the Shelved Events tab. | value: boolean | | enableFilter | Enables the visibility of the text filter toggle. Default is true. | value: boolean | | toggleableFilter | If false, the text filter will not require user interaction to open, and instead will remain open. Default is true. | value: boolean | | enableFilterResults | Enables the visibility of the filters results count message. Default is true. | value: boolean | | enablePreFilters | Enables the visibility of the pre-filter toggle. Default is true. | value: boolean | | enableConfiguration | Enables the visibility of the configuration toggle. Default is true. | value: boolean | ### filter Properties #### active Settings for active alarms. | Name | Description | Property Type | | ---------- | --------------- | -------------- | |text |The alarm events filter text. |value: string | |states|Pre-filters for filter active alarm events. All of the following properties are boolean values. **activeUnacked**: Active and unacknowledged. Default is true.**activeAcked**: Active and acknowledged. Default is true.**clearUnacked**: Cleared and unacknowledged. Default is true.**clearAcked**: Cleared and acknowledged. Default is false. |object | |priorities |Alarm event priority pre-filters. All of the following properties are boolean values.**diagnostic**: Whether to display alarms with diagnostic priority. Default is false. **low**: Whether to display alarms with low priority. Default is true. **medium**: Whether to display alarms with medium priority. Default is true.**high**: Whether to display alarms with high priority. Default is true.**critical**: Whether to display alarms with critical priority. Default is true. |object | |conditions | Gateway side alarm query conditions. All of the following properties are string values.**source**: Filter alarms by alarm source path. Specify multiple paths by separating them with commas. Supports the wildcard \*. **displayPath**: Filter alarms by display path, falling back to the source path if a custom display path in not set. Specify multiple paths by separating them with commas. Supports the wildcard \*. **provider**: Filter alarms by provider.Refer to the [Filtering Alarms](/platform/alarming/alarming.md#filtering-alarms) section on the Alarming page for more information on displayPath and source syntax.|object | |results |Alarm event filtering results configuration and data.**enabled**: Enable filtering results to be written back to props. Value is a boolean. **Note**: Enabling this property may cause a performance decline.**data**: An array of objects representing the current filtered data, if enabled and active. |object | #### shelved Temporarily silence an alarm for a fixed period of time while the alarm event issue is worked on. | Name | Description | Property Type | | ---------- | --------------- | -------------- | |text |The alarm events filter text. |value: string | |results |Shelved alarm filtering results configuration and data.**enabled**: Enable filter results to be written back to props. **Caution**: Doing so may cause performance decline. Default is false. Value is boolean. **data**: An array of objects representing the current filtered data if enabled and active. Value is array.|object| ### rowStyles Properties | Name | Description | Property Type | | ------- | --------------------------------------------------------------------------------------- | ------------- | | activeUnacked | Style settings for rows with activeUnacked alarms.| object | | activeAcked | Style settings for rows with activeAcked alarms.| object | | clearUnacked |Style settings for rows with clearUnacked alarms. | object | | clearAcked | Style settings for rows with clearAcked alarms. | object | |dateFormat|A date format string to be applied against dates. |value: string | #### rowStyles Child Properties Each rowStyles property except dateFormat has the following child properties. For each, a full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md) | Name | Description | Property Type | | ------- | --------------------------------------------------------------------------------------- | ------------- | |base| Base style settings for alarms. |object| |priorities| Style settings for the alarm row based on priority. **diagnostic**: Style for acked alarms with diagnostic priority.**low**: Style for acked alarms with low priority. **medium**: Style for acked alarms with medium priority. **high**: Style for acked alarms with high priority.**critical**: Style for acked alarms with critical priority. |object| ### columns Properties #### active Active alarm event columns to display on load | Name | Description | Property Type | | -------------- | ----------------------------------- | ------------- | | activeTime | Settings for the activeTime column.| object | | displayPath | Settings for the displayPath column. | object | | priority | Settings for the priority column.| object | | state | Settings for the state column. | object | | source | Settings for the source column. | object | | label | Settings for the label column.| object | | name | Settings for the name column. | object | | eventId | Settings for the eventId column. | object | | eventValue | Settings for the eventValue column. | object | | notes | Settings for the notes column. | object | | isActive | Settings for the isActive column. | object | | isAcked | Settings for the isAcked column. | object | | isClear | Settings for the isClear column. | object | | ackTime | Settings for the ackTime column.| object | | ackUser | Settings for the ackUser column. | object | | ackNotes | Settings for the ackNotes column. | object | | ackPipeline | Settings for the ackPipeline column. | object | | activePipeline | Settings for the activePipeline column. | object | | clearTime | Settings for the clearTime column. | object | | clearPipeline | Settings for the clearPipeline column. | object | | deadband | Settings for the deadband column. | object | #### shelved | Name | Description | Property Type | | ---------- | -------------------------------------------------------------------------------- | ------------- | | expires | Settings for the expires column.| object | | shelvedBy | Settings for the shelvedBy column. | object | | sourcePath | Settings for the sourcePath expires column.| object | #### column active and shelved Child Properties Each column type property has the following child properties. | Name | Description | Property Type | | ----------- | ---------------------------- | -------------- | | enabled | Whether the column is enabled. Default is true. | value: boolean | | width | The column's width, which when not strict represents a proportion of the available space, i.e., flex grow. If strictWidth is enabled, the column will be fixed and static. | value: numeric | | strictWidth | If enabled, the width of the column (set with the width property) becomes static. Default is false. | value: boolean | | sort | Default sort order of the column. Options are none, ascending, or descending. | value: string | ### columnsAssociated active Properties Active alarm event associated data columns to display on load. | Name | Description | Property Type | | ----------- | ------------------------ | -------------- | | field | Maps to the associated data value represented by the column. | value: string | | enabled | Whether the column is enabled. Default is true. | value: boolean | | width | The column's width, which when not strict represents a proportion of the available space, i.e., flex grow. If strictWidth is enabled, the column will be fixed and static. | value: numeric | | strictWidth | If enabled, the width of the column (set with the width property) becomes static. Default is false. | value: boolean | | sort | Default sort order of the column. Options are none, ascending, or descending. | value: string | | order | Order to display this column in the table. | value: numeric | ### pager Properties | Name | Description | Property Type | | ------------- | ---------- |---| | enabled | Enables the pager to be displayed. Default is true. | value: boolean | | hide | Visually hides the pager from view. Useful when pager is manipulated in a controlled fashion via the activePage property. Default is false. | value: boolean | | options | Rows to show per pager option. | array | | initialOption | The initial option to use when the table first loads. It must exist as an available option. | value: numeric | | activePage | Represents the current active page and corresponds to the value of the page jump input field. | value: numeric | |shelvedPage| Represents the current shelved page and corresponds to the value of the page jump input field. |value: numeric| ## Scripting See the [Perspective - Alarm Status Table Scripting](perspective-alarm-status-table-scripting.md) page for the full list of scripting functions available for this component. ## Examples ### Example 1 In a Perspective Session, click on the **Filter** ![](2020-01-14_12-57-29.png) button to filter on alarm states and/or use the **Search Bar** ![](2020-01-14_12-58-54.png) to target more specific alarm events. Select from the **Configuration Settings** ![](2020-01-14_12-56-45.png) to change the column headers to display the alarm event data you're interested in. This example uses the Search Bar to find any text with 'High Wind Speed' in the Active, Unacknowledge alarm state. ![](2020-02-11_15-14-46.png) ### Example 2 - Alarm Status Table Row Styles In the Designer, you can change row styles to be different colors for the different priorities for each alarm state. In this example, the rowStyle for the Critical priority for the activeAcked alarm state was changed to green. ![](2019-08-02_14-26-04.png)
