--- title: "Perspective - Simple Gauge" description: "The Simple Gauge component in Perspective provides a way to show realtime values in a range as they change." --- # Perspective - Simple Gauge > The Simple Gauge component in Perspective provides a way to show realtime values in a range as they change. ![" "](simple-gauge.png) **Component Palette Icon:** ![" "](simple-gauge-icon.png) The Simple Gauge component in Perspective provides a way to show realtime values in a range as they change. This gauge is a less complicated version of the [Gauge](appendix\components\perspective-components\perspective-chart-palette\perspective-gauge\perspective-gauge.md) component. It has just one axis, is easy to configure and is customizable in its appearance. The Simple Gauge component has three pre-configured [variants](ignition-modules\perspective\working-with-perspective-components\working-with-perspective-components.md): - Half Circle - Default layout with a half-circle gauge. - 3/4 Circle - Layout with a 3/4 circle gauge. - Full Axis - Layout with a full axis gauge. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules\perspective\working-with-perspective-components\bindings-in-perspective\bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules\perspective\working-with-perspective-components\perspective-component-properties.md) page. |Name|Description|Property Type| |---|---|---| |value|Numeric value for the gauge to display. Default is 0.|value: numeric| |minValue|Minimum gauge value for this gauge. Default is 0.|value: numeric| |maxValue|Maximum gauge value for this gauge. Default is 100.|value: numeric| |startAngle|Radial position for the start of the gauge's arc. Default is 180.|value: numeric| |endAngle|Radial position for the end of the gauge's arc. Default is 360.|value: numeric| |arc|The arc is a radial band that displays the gauge's value.**width**: Width of the line (in pixels) that represents the arc. Default is 20. Value is numeric.**color**: Color of the arc line showing the gauge's value. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector](appendix\reference-pages\color-selector-reference\color-selector-reference.mdx). **cornerRadius**: Amount to round the edges of the arc. Default is 0. Value is numeric.|object| |arcBackground|Background or 'track' for the gauge arc. Shows shape and total potential value behind the arc.**color**: Color of the arc background. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value.**opacity**: Opacity of the arc. 0 is fully transparent, 1 is fully opaque. Value is numeric.|value: numeric| |label|The label for the gauge is displayed as text, with optional units.**visible**: Indicates whether or not the label is visible. Default is true (visible). Value is boolean.**size**: Font size to display label text. Default is 25. Value is numeric.**offsetX**: Offset position on the x axis, relative to the middle of the gauge. Value is numeric.**offsetY**: Offset position on the y axis, relative to the middle of the gauge. Value is numeric.**color**: Color of the label.**units**: Any unit information to append to the value on the label. Value is string.**maxDecimal**: Maximum number of digits after decimal to display in the label. If null, full value will display. Value is numeric.|object| |animate|Whether needle should be animated in a sweeping motion when value changes. Default is false.|value: boolean| |style|Sets a style for this gauge. Full menu of [style options](appendix\reference-pages\style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules\perspective\styles\style-classes\style-classes.md).|object| ## Component Events The [Perspective Event Types Reference](appendix\reference-pages\perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules\perspective\working-with-perspective-components\component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![" "](simple-gauge-example.png) |Property|Value| |---|---| |Value|32.4567| |props.arc.width|15| |props.arc.cornerRadius|25| |props.arc.color|#FF8C00| |props.arcBackground.opacity|0.4| |props.label.units|psi| |props.label.maxDecimal|1|
