--- title: "Swapping vs. Opening" --- # Swapping vs. Opening > >
The two primary window navigation operations are: swapping and opening. ## Swapping When Ignition swaps a window, it closes the window and then opens another window in its place. This operation can be performed on windows in any state: docked or floating, maximized or not. The **Start Maximized** and **Dock Position** properties of the window that is being swapped *in* will be ignored - it will take the dock and maximized state of the window that it is replacing. This operation is so common in the typical navigation strategy that there is even a version of the swapping function dedicated to it, the **swapTo** function. This function eliminates the need to specify the window to swap from - you only need to specify the window to swap to. It will take the current window - that is, the current maximized window - as the window to swap from. See the following functions for more information: * [system.nav.swapWindow](appendix\scripting-functions\system-nav\system-nav-swapWindow.md) * [system.nav.swapTo](appendix\scripting-functions\system-nav\system-nav-swapTo.md) ## Opening Opening and closing are the basic window navigation options. Opening a window opens the window at the same size it was in the Designer, unless the **Start Maximized** property is **true** or the **Dock Position** is *not* **Floating**. To make a floating popup window open at a specific location, make sure to set the **Location** property of the window in the Designer. If the window was recently open, it will open in its last state due to window caching. See the [Window's Cache Policy](visualization-and-dashboards\windows\working-with-vision-windows\window-properties\window-properties.md#window-properties) property for more information. See the following function for more information: * [system.nav.openWindow](appendix\scripting-functions\system-nav\system-nav-openWindow.md) ## Open or Swap a Window with Scripting 1. In the Designer, right-click on a component and select **Scripting**. :::tip Usually a button is used to open a window. ::: 2. Select the appropriate [Event Handler](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) for the component. :::note Event Handlers are different for different components. There are a number of different options to choose from based on how and when you want your window to open or swap. If you are using a button, select the **actionPerformed** Event Handler. ::: 3. Select the **Navigation** tab. 4. Click the **Open/Swap** radio button. 5. Select either the **Open/Swap** radio button as your Navigation strategy. Typically, you want to use the **Open** option for Popup and Docked windows, and the **Swap** for the Main windows that will be in the background as you can only view one at a time. 6. Select the Window you want to open/swap from of the **Window** dropdown. ![swapping vs opening step 6](swapping-vs-opening-step-6.png)
