--- title: "Template Composition" --- # Template Composition > ## Templates Within Templates You can embed templates inside of other templates. The nested template behaves like a component. This can be useful if the project can be broken down into many similar, small parts. Instead of building a template for a tank with a guage, a motor with a guage, and a compressor with a guage, it might instead be better to first build a simple guage template that can then be added to each of three templates so that it already is setup correctly. ### To Nest a Template Inside Another Template 1. Drag an existing template from the **Project Browser** into the template that you are currently working on. 2. Bind the nested template properties to the properties located on the parent template's **Custom** properties such as UDT parameters. I can easily use an indicator template that I made to display values from a motor template, or values from a tank template, as long as I setup the indicator template with the proper indirection. This way, I only have to setup the indicator once and write in a few parameters, instead of having to customize the indicator the same way for every template that it gets added to. ![" "]() ![" "]()
