--- title: "Driven Scan Class - One Shot" --- # Driven Scan Class - One Shot >
The Driven scan class can be configured as a One-shot scan class. This will not run at a rate, but instead it will be triggered by a change in the driving Tag's value. One-shot polling executes once when the condition becomes true, then waits for that condition to become false then true again. This makes it follow a 'rising edge' or 'falling edge' pattern. Let's make a Driven One-shot scan class that only updates once when a Memory Tag goes to true. We are using a Memory Tag so a user can change the value when they want to poll the PLC. This is actually a good example of how an operator can poll the PLC for new values whenever they want to, using a refresh button on the screen. ## To Create a Memory Tag 1. In the **Tag Browser**, right click on the Tags folder, then go to **New Tag** > **Memory Tag** to create a memory Tag. The Tag Editor will open. 2. In the **Tag Editor**, enter the following: - Tag Name: **One Shot Trigger** - Value: **false** - Data Type: **Boolean** ![" "]() 3. Click **OK** to add the One Shot Trigger Tag to the Tag Browser. ## To Make a Driven One-shot Scan Class Once you have your driving Tag created, add a Driven - One shot scan class that lets a user poll Tags manually. 1. In the **Tag Browser**, click on the **Timer** icon (![" "]()) to open the Scan Class Editor. 2. Create a new scan class by clicking on the **green +** icon on the lower-left of the window. 3. Enter the name of the scan class. For example, you can name it **Driven One Shot**, and set the **Mode** to **Driven**. This scan class executes based on the condition you set on the **Driving Tag**. Ignore the slow and fast rate since they are not used. 4. Click on the **Tag** icon next to the **Driving Tag** box, and choose the Tag you want to set the condition on, and click **OK**. This examples uses the **One Shot Trigger** Tag that was just created. 5. Set the **Operator** property to = and the **Value** property to **1**. 6. Check the **One-shot Execution** property. Click OK. ![" "]() 7. Next, select all the other Tags that you want to run in this scan class (i.e., **Level**, **Pressure**, and **Temperature**). Right click on the selected Tags, and the **Tag Editor** will open. To change the scan class, choose **Driven One Shot** from the dropdown, and click **OK**. ![" "]() ![" "]() 8. In the **Tag Browser**, check the One Shot Trigger Tag to set the value to **true**, and you will see the values update once, and then stop. Uncheck the One Shot Trigger Tag, to set the value to **false**, and check it again to set it to **true**, and you will see the values update again. ![" "]() 9. Drag a **Momentary Button** component onto a window, then drag your **One Shot Trigger** Tag onto the button. Now your operators can request new values and the button automatically resets the Tag.
