--- title: "SQL Stored Procedures" --- # SQL Stored Procedures > For the uninitiated, Stored Procedures are a series of predefined SQL statements that are configured and stored in the database, and can be easily called from another application, such as Ignition, with a single statement. Conceptually, they are very similar to a scripting function: parameters may be passed to them, they can utilize looping and conditional logic, and can return a value. ## Stored Procedure Syntax Stored procedures are created and maintained in your database. As a result, the creation of a stored procedure is outside the scope of the Ignition User Manual: the commands used to create a stored procedure vary per database. In regard to calling a Stored Procedure, the syntax can also differ. ### SQL Server The EXEC command is utilized to execute a stored procedure. ```sql title="Pseudocode - Executing a Stored Procedure in SQL Server" EXEC dbo.myStoredProcedure ``` Parameters may be passed to the Stored Procedure. SQL Server's documentation has more details on utilizing parameters with Stored Procedures. ```sql title="Pseudocode - Executing a Stored Procedure in SQL Server with Parameters" EXEC dbo.myStoredProcedure @myParam = 100, @AnotherParameters = 'Hello' ``` ### MySQL MySQL uses the CALL command to execute a Stored Procedure. Note the parentheses characters at the end, as they must be present even when the Stored Procedure is not utilizing parameters. ```sql title="Pseudocode - Executing a Stored Procedure in MySQL" CALL myStoredProcedure() ``` If parameters are defined, they can be passed via the parenthesis, similar to how functions work in Python. ```sql title="Pseudocode - Executing a Stored Procedure in MySQL with Multiple Parameters" CALL myStoredProcedure(100, 'Hello') ``` For information on the creation of a stored procedure, as well as proper SQL syntax to call a Stored Procedure, reference your database's documentation. Alternatively, if you have a database administrator, they can typically help with the creation and execution of a Stored Procedure. ## Calling Stored Procedures in Ignition There are several locations in Ignition where Stored Procedures may be utilized from. ### SQL Query Bindings Instead of typing a query directly into a [SQL Query binding](visualization-and-dashboards/property-binding-types/sql-query-binding/sql-query-binding.md), a Stored Procedure may be executed instead. Assuming a MySQL database contains a Stored Procedure named 'return_all_bays', we can call the procedure on a binding with the following: ```sql title="SQL - Calling a Stored Procedure in MySQL" CALL return_all_bays() ``` As with all bindings, Tag ![" "](tag_blue_24.png) and Property ![" "](propertyReference.png) references may be utilized by clicking the appropriate icons in the binding window. ![" "](1-spParams.png) ## Stored Procedure Groups One of the easiest ways to utilize Tags with a Stored Procedure is to use the [Stored Procedure Group](sql-bridge-transaction-groups/transaction-group-examples/stored-procedure-group/stored-procedure-group.md). Parameters can be easily assigned to each item in the group, and utilize all of the features of a [Transaction Group](sql-bridge-transaction-groups/understanding-transaction-groups/understanding-transaction-groups.md), such as scheduled execution and triggers. Each item in the group is linked to a specific parameter in the Stored Procedure. Any IN or INOUT parameters can write directly to the Tags, while new values can be fed into OUT and INOUT parameters allowing you to easily move data from Tags into the database with the Stored Procedure. ![" "](2-storedProcedure.png) ## Stored Procedures in Python Scripts There are a few ways to call a Stored Procedure from a script in Ignition. ### Using createSProcCall and execSProcCall The recommended approach to calling a Stored Procedure from a Python script in Ignition typically involves two main steps: 1. Calling [system.db.createSProcCall](appendix/scripting-functions/system-db/system-db-createSProcCall.md) to create a call context, or object that effectively represents the impending stored procedure call. This object can be used to specify parameter values that will be passed to the Stored Procedure. 2. Using [system.db.execSProcCall](appendix/scripting-functions/system-db/system-db-execSProcCall.md) to execute the Stored Procedure. Once the Stored Procedure has been executed, the call context generated in step #1 can be used to reference any values that were returned. ### Other System Functions Technically, most other system functions in the "db" library, such as [system.db.runPrepQuery](appendix/scripting-functions/system-db/system-db-runPrepQuery.md), can be used to call a Stored Procedure. We generally recommend against this, as [system.db.createSProcCall](appendix/scripting-functions/system-db/system-db-createSProcCall.md) and [system.db.execSProcCall](appendix/scripting-functions/system-db/system-db-execSProcCall.md) are better suited to work with Stored Procedures and have some additional functionality not found in the other db functions.
