--- title: "Run Always vs. Triggered Items" --- # Run Always vs. Triggered Items > In the Transaction Group workspace, you can set the Expression items in a group to execute in two different ways: + **Run-Always** in which the Expression items will execute at the groups rate (based on the **Execution Scheduling** settings on the **Action** tab). + **Triggered** in which the Expression items run when the group is triggered (based on the settings on the **Trigger** tab). If on the **Trigger** tab, the option **Execute this group on a trigger** is not selected, the items in the **Run-Always Expression Item** area and **Triggered Expression Items** area will all execute at the same time. The advantage selecting the **Execute this group on a trigger** option is that is gives you flexibility on when the expression items are executed which may result in easing the load on a database.
