--- title: "Tag Security" --- # Tag Security > ## Tag Access Rights Tag security is often the best way to configure security for data access. By defining security on a Tag, you affect the Tag across all windows in all projects, as opposed to configuring component security on each component that displays or controls that Tag. If a user opens a window in the Client that has components that are bound to a Tag that the user doesn't have clearance to read or write to, the component will get a forbidden overlay. ![](access_denied_overlay.png) See also: [Quality Overlays](tags/understanding-tags/tag-quality-and-overlays.md), [Permission Properties](tags/understanding-tags/tag-properties.md). ### To Set the Access Rights to a Tag You can add read/write security to individual Tags or multiple Tags in the Designer. In order to change permissions on a Tag, you have to make changes in two places. 1) Set the **Access Rights** property to Custom. 2) Add Role(s) to the **Permissions** page. 1. In the **Tag Browser**, edit a Tag by double-clicking on the Tag. 2. In the **General** tab, from the **Access Rights** drop-down, select **Custom**. ![](custom-access-write.png) 3. Select the **Permissions** tab on the left side, and from the **Add a Role** drop-down select a role. Click the **Add** button. 4. Change each role's **Access** rights by selecting the **Read Only** or **Read/Write** option. If a user does not have any of the listed roles, they will be denied both read and write permissions. ![](access-permission.png) 5. Click **OK**. Now the user has the Read/Write permission to interact with the Tag. ## Tag Access Rights with Security Zones Tag permissions can also include [Security Zones](security/security-zones/security-zones.md). Security Zones allow you to not only limit Tags by a user's role, but also by area. They are setup in the same way as setting the Access Rights just for a user, except a zone must also be specified. It does require that Security Zones be configured, and a few Gateways connected in a Gateway Network. Leaving the Security Zone empty will assume the access permission is for all zones. ![](multiple-roles-zones.png)
