--- title: "Add/Edit/Delete Projects" --- # Add/Edit/Delete Projects > For a quick walk-through to create a new project and start developing, see the [Quick Start Guide](getting-started\quick-start-guide\quick-start-guide.md). ## Creating a Project The first step in working with a project is creating one! When you [launch the Designer](designer\launching-designer.md), the **Open/Create Project** window is displayed. You will have the option to create a new project or open an existing project. ![New Project Setup](new-project-setup.png) To create a new project, click on **New Project** and define following information: * **Project Name**: A unique name for the project in the system. The name can only consist of alphanumeric characters and the '_' character. Spaces and other special characters are not supported. :::note It is not advisable to change the name after it's been created. Instead, change the **Project Title** if you want to change how the project appears later. ::: * **Project Title**: This is the name that will be displayed on the launch page of the Gateway and in the runtime Client. There are no restrictions to special characters or spaces. * **Authentication Profile**: The profile to use for granting access to the project. For more information or to add users, see [Security](security\security.md). * **Default Database**: Any queries to the database will use this default [database connection](database-connections\connecting-to-databases\connecting-to-databases.md) unless explicitly specified otherwise. * **Default Tags Provider**: The primary [Tag provider](tags\tags.md) for the project. Most installations will likely only have one provider, but in situations where there are more than one, this is the provider that will be used unless explicitly specified otherwise. * **Project Template**: Gives you the option to choose a quick start template for your project. Most people start with a simple 1-tier navigation option. Click the dropdown to see all the available options. ## Managing Projects Once you have a project or two (or twenty) setup, you might want to change some of the base settings. You can manage the projects from the **Configure** section of Gateway by going to **System** > **Projects**. The **Project** window is displayed showing all your projects. To the right of the project name, click the **More** button, and here you can **edit**, **delete**, view **details**, **copy**, or **export** your project. :::note You can manage many of these things in the Designer, and much more (such as the Client Poll Rate, Publish Mode, etc.,). See the [Project Properties page](projects\project-properties\project-properties.md) for more information. ::: ![managing projects](managing-projects.png) ### Viewing the Details of a Project To view the project details, go to the Configure section of the Gateway webpage, and select System > Projects. Find your project, press the More button to the right of the project name, and select details. The details link on the Project window, takes you to the Project details for `` page where you can choose to view the Published or Staging version of the project, and view the project's edit history. :::note Have you ever seen **``** with those weird greater than/less than signs before? We do this a lot in the user manual because Ignition will often use your specific names. Don't worry about it, this just means you should expect to see whatever your name is in that spot. IE: If your project name is "**Project 1**", then you will see Project details for '**Project 1**'. ::: ### Editing a Project To edit some of the project settings, go to the **Configure** section of Gateway, and then to **System** > **Projects**. You will see a list of all your projects. Click **edit** to the right of project name in the list. The **Edit Project** page is displayed. You can now change some of the project settings such as project name, description, and title. You can also change connections to the Authentication profile, default database, and default tag provider. Many of these settings can be modified in the Designer too, but it is important to note that you cannot change any of these project settings from the Gateway if the project is currently open in a Designer. ### Deleting a Project Be aware that once you delete a project, it cannot be undone, a deleted project is gone forever (unless it can be recovered from a [backup](gateway\making-backups-and-restoring\gateway-backups.md) or [auto-backup](gateway\making-backups-and-restoring\gateway-automatic-backups.md)). Always make a project export or Gateway Backup before deleting a project. To delete a project, go to the **Configure** section of Gateway, and then to **System** > **Projects**. You will now see a list of all your projects. To the right of the project name in the list, look for **delete** and click on it. This deletes your project. ### Copying a Project Copying your project is useful when you need a *snapshot* of a project before starting major changes, or for creating a starting point for a new project based on an old one. To copy a project, go to the **Configure** section of Gateway, and then to **System** > **Projects**. You will now see a list of all your projects. To the right of the project name in the list, click **copy**. This creates a copy of your project. ## Project Settings ### Published vs Staging Each project can have two distinct versions at the same time: the [**Staging** version and the **Published** version](gateway\versioning.md#project-version-considerations). Having a staging version allows you to make changes to a project, save the changes, and test out the changes before "publishing" it to a production environment. Normal Vision module Clients run the published version of a project. However, by launching a Client in a special mode (from the Designer or from the Configure section of the Gateway), you can launch a Client that runs the **staging version** of that project. This staging Client will receive updates on every save, where the production Clients receive updates only on publish. This lets you test out your changes to the project in an actual Client, which is more realistic than the Designer's preview mode. Not all aspects of a project use this system. It is primarily intended for systems such as the Vision module's Clients. Features that run persistently on the Gateway such as Tags, the SQL Bridge's Transaction Groups, and Gateway-side scripting always run the most recently saved changes (the Staging version). Since these features by definition must run in exactly one place, they cannot be effectively "tested out" by simultaneously running a staging version alongside a published version. In the Designer, choose the **Project** > **Properties** menu item, then go to the **Project** > **General** page to set the **Publish Mode**. By default, a new project is configured to be in **Auto** publish mode, however you can change it to **Manual** publish mode. * In the default **Auto** mode, when you want to save your project, Designer lets you do a **File** > **Save and Publish**, which means both the Staging and the Published versions will be the same and identical. * In **Manual** mode, when you want to save your project, Designer lets you do both a **File** > **Save**, or a **File** > **Publish**. **File** > **Save** updates the Staging version, and **File** > **Publish** updates the Published version. ![project properties publishing settings](project-properties-publishing-settings.png) ### Project Versioning and History Each project keeps a log of recent changes. These include both saves and publishes. Every save increments a number called the "edit count" for the project, which can be used like a serial number. The user, time, affected resources, and a commit messages (described next) are logged as well. To learn more about versioning in Ignition, refer to the section on [Versioning](gateway\versioning.md). ### Commit Messages A project may be configured to prompt the user making changes to describe those changes, either on every publish event, or on every save and publish event. These messages, called commit messages, are used to describe the changes that have been made to the project. By inspecting the project's history and reading these commit messages, you can learn what changes have been made to the project, for what reason, and by whom. ## Concurrent Project Development Often in large facilities there are multiple people working on the same project. Multiple Ignition Designers can be launched concurrently, and everyone can work on the same project at the same time. Because everything is controlled in the Gateway, there is no merging or syncing required when you save your changes. When a particular resource (window, template, etc) is being edited, it will be locked, and the other designers won't be able to modify the locked resources. When the resource is closed and saved, it's automatically unlocked. Concurrent edits are pushed to other designers only when you update your project. You can do this by going to the menubar in the Designer and selecting **File** > **Update Project**.
