--- title: "New in this Version" --- # New in this Version > ## About Version Features This section is devoted to new features introduced to Ignition. Any pages in this user manual that contain features that were added will be highlighted like this: ## Upgrading Ignition See the [Installing and Upgrading](getting-started/installing-and-upgrading/installing-and-upgrading.md) page ## New in 7.9.18 ### Transaction Groups * Enabling the [Set DB Values to Default](sql-bridge-transaction-groups/understanding-transaction-groups/understanding-transaction-groups.md#advanced-settings) setting will clear the latched value, setting it to a default value. ### EAM * As of release 7.9.18, you can [send projects and project resources](enterprise-administration/agent-tasks/send-project/send-project.md) across major Ignition platform versions, for example from release 7.9 to 8.1. ## New in 7.9.17 ### Gateway Redundancy Setting Backported the Master Node "Config Update Queue Size" [Redundancy setting](gateway/ignition-redundancy/setting-up-redundancy.md) which is the maximum size of config updates allowed before a full transfer is performed. ### Gateway Configuration File Reference Added an option to control how much information is given to clients/designers in [error messages](appendix/reference-pages/gateway-configuration-file-reference.md#suppressing-error-message-details). ### Designer Find/Replace The Designer [Find and Replace](designer/find-and-replace.md) now includes Tag property values as well as substrings in Tag Event Scripts. ## New in 7.9.16 The Ignition 7.9.16 version contains only bug fixes and no new features. ## New in 7.9.15 ### Scale Out Architecture As of 7.9.15, launching clients behind a [load balancer](getting-started/system-architectures/scale-out-architecture.md) works, but the projects on each gateway MUST have identical UUIDs, meaning that all visualization gateways must be restored from the same Gateway backup, as project imports won't work. ### SECS/GEM Messages As of 7.9.15, custom response handlers will execute when receiving messages over the [SECS-1 (serial) protocol](opc-ua-and-device-connections/secs-gem/sec-gem-messages.md). ## New in 7.9.14 ### OPC-UA Added "Advanced Configuration" page when configuring new UA client connections and automatic host override. ### Logix Driver The port on Logix driver device connections can now be configured. ### Active Directory The Cache Validation Timeout property can all now be disabled if set to a number less than zero on all user sources. ### Gateway Configuration File Reference ## New in 7.9.13 Cloud Templates have been migrated to the new [Ignition Exchange](https://inductiveautomation.com/exchange/). ### Audit Profiles Ignition Gateways can now create an Internal [Audit Profile](security/using-audit-profiles/using-audit-profiles.md#audit-profile-types) allowing an Ignition Gateway to store audit records without an external SQL database. ### Connecting to a SLC Device Added a Browse Cache Enabled setting to [SLC device connections](opc-ua-and-device-connections/allen-bradley-ethernet/connecting-to-slc/connecting-to-slc.md), which determines if browse results for the device should be cached. ### File Menu Ignition Exchange added as function in the [File Menu](designer/designer-user-interface/designer-user-interface.md#file-menu) of the Designer. ### Gateway Security Added the capability to set [custom SSL Key Store](security/gateway-security.md#when-using-ssl) alias and passwords. ### Gateway Settings Added Audit Profile option to [Gateway settings](gateway/gateway-settings/gateway-setup.md#gateway-property-reference). ### Tag Export Localization When [exporting tags](tags/understanding-tags/importing-and-exporting-tags.md), we now include the designer's system locale and format numbers in the output according to that locale. ### Web Browser Component The [Web Browser](appendix/components/web-browser/web-browser-component.md) now has an Initialize extension function that triggers when the component is initialized. ### Enterprise Administration [EAM Agent Restore Backup](enterprise-administration/agent-tasks/agent-tasks.md#agent-tasks) now includes an option to "Install Modules," providing an opportunity to apply modules while restoring from an Agent Backup. ### Alarm Journal * Ignition Gateways can now create an Internal [Alarm Journal Profile](alarming/alarm-journal/journal-properties-and-tables.md), which stores journal entries in the Gateway's internal database, instead of an external SQL database. * Added a local [Audit Profile](security/using-audit-profiles/using-audit-profiles.md) option to standard edition Gateways. ## New in 7.9.12 ### Alarm Status Table Added the Duration Format property to the [Alarm Status Table](appendix/components/alarming/alarm-status-table/alarm-status-table.md). Format for the time units on the Active Duration column: Long, Short, Compact, and Abbreviated. ### Voice Notification Module Added a [non-interactve alarm feature](alarming/alarm-notification/customizing-alarm-notification/custom-email-sms-and-voice-scripts.md#voice-call-script) to stop any call scripts from being read by removing all text from that field. ### OPC UA Endpoint Two new server properties were added to the [OPC UA connection settings](opc-ua-and-device-connections/opc-ua-connections-and-settings/opc-ua-connections-and-settings.md#connecting-to-a-opc-ua-server---7913-and-prior). Added Connect Timeout when opening a socket connection to a remote host, and Acknowledge Timeout to wait for an acknowledge message in response to the client's Hello message. ### Audit Log Updated the [Audit Log information](security/using-audit-profiles/view-audit-information.md) to include changes made directly to the Tags in the Tag Browser, as well as with scripting functions. ### SECS/GEM Module [SECS/GEM Module](opc-ua-and-device-connections/secs-gem/secs-gem.md) added support for Oracle database. ### Scripting Function system.eam.runTask New scripting function [system.eam.runTask](appendix/scripting-functions/system-eam/system-eam-runTask.md) is available. It takes the name of a task as an argument as a string (must be configured on the Controller before hand), attempts to execute the task. To run in the client, the user needs a [role-based permission](security/managing-users-and-roles.md). This permission is disabled by default. ## New in 7.9.11 ### Gateway Backups Gateway Backup default filename format updated: **GatewayName_Ignition-backup-YYYYMMDD-HHMM.gwbk** Added the option to change a Gateway Name when [restoring a GWBK file](gateway/making-backups-and-restoring/gateway-restore.md). ### Launching Clients Applet launch option has been removed from Gateway home page, Client Launcher, and direct launch links. Applet client is still available if the exact url is used. ### Launching Designer Updated skeleton projects area available when creating a new project. ### Expression Language Added an Expression function to test Tag quality: [isGood()](appendix/expression-functions/logic/isGood.md). Numeric Aggregate expressions now return null, instead of 0 when there are no valid inputs. ## New in 7.9.10 ### Native Client Launcher The [Native Client Launcher](clients/native-client-launchers.md) now has Java 9 embedded in it, so java no longer needs to be installed to run the NCL. ### Named Queries [Named Queries](sql-in-ignition/named-queries/named-queries.md) now return the fallback value when no value gets returned, lining up with SQL calls elsewhere in Ignition. ## New in 7.9.9 ### Edge The 500 tag limit in Edge [has been removed](getting-started/ignition-edge/ignition-edge.md#tag-limit). Edge can now support an unlimited number of tags, just like Ignition. ### Mobile Module Added the [Session Invalidation Retry Count property](clients/about-mobile-clients/mobile-client-settings.md), which allows mobile clients to attempt to reconnect if the session is invalidated. ### MySQL The installer contains a [JDBC driver that is compatible with MySQL 8.0+](database-connections/database-connections.md#supported-databases-in-ignition). New installations of Ignition will utilize the new driver, while older installations that are upgraded to 7.9.9+ will use the older driver to preserve connections to legacy MySQL installations. ### Named Queries Named Query parameters [now support byte arrays](sql-in-ignition/named-queries/named-query-parameters/named-query-parameters.md#byte-arrays). ### Scripting The [system.util.getSessionInfo](appendix/scripting-functions/system-util/system-util-getSessionInfo.md) function now supports the use of keyword arguments. ### Vision The Document Viewer component has been deprecated. Similar functionality can be achieved with other Input components by utilizing [HTML formatting](visualization-and-dashboards/understanding-components/html-in-ignition/html-in-ignition.md). Instances of the Document Viewer that were created before this version will still exist after upgrading, but new instances can not be created from the Component Palette. ## New in 7.9.8 ### Alarming A new [Label property](tags/understanding-tags/tag-properties.md#alarming-properties) has been added to alarm configurations, allowing a dynamic name to be associated with each alarm. ### Designer When resolving conflicts during a [Project Restore](gateway/making-backups-and-restoring/project-restore.md), you can now choose to Overwrite All or Skip All resources in the project file. ### Expressions Colors entered as strings with the [toColor](appendix/expression-functions/type-casting/toColor.md) function can now use American or British English spelling throughout (eg, 'grey' or 'gray') ### Reporting When scheduling a report, the [Email Action](reporting/report-schedules/scheduling-actions/scheduling-actions.md#email-action) can now specified a "reply to" email address. Additionally, the [system.report.executeAndDistribute](appendix/scripting-functions/system-report/system-report-executeAndDistribute.md) function can also specify a "reply to" when emailing a report. ### Scripting A new optional parameter has been added to both the [system.dataset.dataSetToExcel](appendix/scripting-functions/system-dataset/system-dataset-dataSetToExcel.md) and [system.dataset.exportExcel](appendix/scripting-functions/system-dataset/system-dataset-exportExcel.md) functions. This parameter allows NULL values to be represented as empty cells, instead of defaulting to a 0. Both [system.tag.editTag](appendix/scripting-functions/system-tag/system-tag-editTag.md) and [system.tag.editTags](appendix/scripting-functions/system-tag/system-tag-editTags.md) can now be used to edit members of a nested UDT instance. Introduced the [system.math](appendix/scripting-functions/system-math/system-math.md) library, providing quick access many common aggregates. ### Security The Gateway can now be configured to adhere to a [HTTP Strict Transport Security (HSTS)](security/gateway-security.md) policy. ### SFC The return parameters provided by the [Enclosing Step](sequential-function-charts/SFC-elements/enclosing-step.md) can now be assigned to scope parameters. ### Web Browser Component The [Web Browser Component](appendix/components/web-browser/web-browser-component.md) has been updated to utilize version 6.18 of the JXBrowser. ## New in 7.9.7 ### Scripting Added the [system.dataset.formatDates()](appendix/scripting-functions/system-dataset/system-dataset-formatDates.md), [system.dataset.appendDataset()](appendix/scripting-functions/system-dataset/system-dataset-appendDataset.md), [system.dataset.clearDataset()](appendix/scripting-functions/system-dataset/system-dataset-clearDataset.md), and [system.dataset.addRows()](appendix/scripting-functions/system-dataset/system-dataset-addRows.md) functions to allow for greater control over datasets. Added the [system.user.isUserScheduled()](appendix/scripting-functions/system-user/system-user-isUserScheduled.md) and [system.user.getScheduledUsers()](appendix/scripting-functions/system-user/system-user-getScheduledUsers.md) functions to allow for greater control over datasets. ### Reporting The configureChart function that is present on all Report Charts can now access Report Parameters and Datasets. ### Tags Added new [Client System Tags](tags/system-client-and-diagnostic-tags/system-client-and-diagnostic-tags.md) that provide Date Formats that change with Locale. Added a new [Gateway System Tags](tags/system-client-and-diagnostic-tags/system-client-and-diagnostic-tags.md) for system uptime (in seconds). ### Logs Added [MDC Key Filters](gateway/gateway-overview/status/diagnostics.md#logs) that allow you to filter the Logs in the Gateway by an MDC Key. ### Security Added the ability to shelve remote alarms. This has also added a new setting for [Service Security](security/security-zones/security-zones.md) under the Alarming section. ### Transaction Groups Added [two new properties](sql-bridge-transaction-groups/understanding-transaction-groups/understanding-transaction-groups.md#set-null-db-values) of Transaction Groups that will substitute in a default value for a group item, instead of using a value of NULL. ### Components The [Alarm Status Table](appendix/components/alarming/alarm-status-table/alarm-status-table.md) now has a getAlarms() function that will grab the alarms currently listed in the table. ### SECS/GEM Can now send a custom response when receiving certain messages from the equipment using the Message Handler system. ## New in 7.9.6 ### Java 9 Ignition now supports Java 9 for the Gateway, Clients, and Designers. ### Named Queries Named Queries may now be called from [Client Tags](sql-in-ignition/named-queries/named-queries.md). SQL Query bindings with an enabled Update Query that are converted to a Named Query will now create [two separate Named Queries](sql-in-ignition/named-queries/named-query-conversions/named-query-conversions.md): a Select Query, and an Update Query. ### EAM Global Resources, as well as the whole Global Project, may now be selected as the source for the [Send Project and Send Project Resources](enterprise-administration/agent-tasks/send-project/send-project.md#send-project-resources-task) tasks. ### OPC-UA The [maximum number of references per node](opc-ua-and-device-connections/opc-ua-connections-and-settings/opc-ua-connections-and-settings.md#opc-ua-server-properties) on an OPC-UA server can now be configured. ### Scripting Added the [system.db.clearNamedQueryCache](appendix/scripting-functions/system-db/system-db-clearNamedQueryCache.md) and [system.db.clearAllNamedQueryCaches](appendix/scripting-functions/system-db/system-db-clearAllNamedQueryCaches.md) functions to allow for more control over the cached generated by Named Queries. ### Tags [Array OPC Tags](tags/understanding-tags/array-and-dataset-tags.md) can now write back to the device. ## New in 7.9.5 ### Scripting Added a scripting function [system.file.openFiles()](appendix/scripting-functions/system-file/system-file-openFiles.md) to allow for the opening of multiple files. The scripting function [system.net.sendEmail()](appendix/scripting-functions/system-net/system-net-sendEmail.md) now has a new replyTo property, allowing you to set a reply to field for your email. Added the scripting functions [system.user.addRole()](appendix/scripting-functions/system-user/system-user-addRole.md), [system.user.editRole()](appendix/scripting-functions/system-user/system-user-editRole.md), and [system.user.removeRole()](appendix/scripting-functions/system-user/system-user-removeRole.md) to allow roles to be customized in scripting. ### Expressions Added [isAlarmActiveFiltered](appendix/expression-functions/alarming/isAlarmActiveFiltered.md) expression function, which as a more filtered version of [isAlarmActive](appendix/expression-functions/alarming/isAlarmActive.md), allowing you to more precisely control what triggers the expression. ### Reports The [Report Table component](appendix/components/reporting-components/report-design-components/report-component-table/report-component-table.md) can now have cells be multi selected using shift or alt. It also has new/modified table group properties Start on New Page and New Page per Row. Added a Report Loading property into the [Report Viewer](appendix/components/reporting-components/report-viewer/report-viewer.md) component. Reports can now be exported using the [XLS format](reporting/reporting.md) using the scheduled actions. ### Datasets [PyDataSets](scripting/python-scripting/variables-datatypes-and-objects/datasets.md) can now be accessed using the Dataset functions. ### User and Schedule Management The [User Management component](appendix/components/admin/user-management/user-management.md) and the [Schedule Management component](appendix/components/admin/schedule-management/schedule-management.md) now have properties that allow you to customize their color schemes. ### EAM Added a new [Send Tags](enterprise-administration/agent-tasks/send-project/send-project.md#send-tags-task) task, which allows tags to be sent to other Gateways through EAM. ### Text Area The [Text Area component](appendix/components/input/text-area.md) now has a Tab Size property that allows you to set the size of tab characters. ### SFCs [Sequential Function Charts](sequential-function-charts/sequential-function-charts.md) now support redundancy and persistence. ## New in 7.9.4 ### Named Queries Introduced [Named Queries](sql-in-ignition/named-queries/named-queries.md), a new resource that allows a project to request the execution of preconfigured queries. This includes the addition of a new type of binding, the [Named Query Binding](visualization-and-dashboards/property-binding-types/named-query-binding/named-query-binding.md), a new type of report datasource, the [Named Query Datasource](reporting/report-data/named-query-data-source/named-query-data-source.md), as well as a new scripting function, [system.db.runNamedQuery()](appendix/scripting-functions/system-db/system-db-runNamedQuery.md). ### Client Permissions Added Project Properties to [limit client access to certain tasks](projects/project-properties/project-properties.md#client---permissions). When restricted, access may be granted by Role and/or Security Zone. ### Dynamic Rosters Notification Blocks in Alarm Pipelines cay now dynamically generate a Roster with the new [Calculated roster type](alarming/alarm-notification/alarm-notification-pipelines/pipeline-blocks/notification-block.md#calculated). ### Linear Regression Added a new [Calculated Pen](historian/using-the-easy-chart/easy-chart-calculated-pens/easy-chart-calculated-pens.md) option for the Easy Chart. ### Gateway Message Handler Security [Gateway Message Handlers](scripting/scripting-in-ignition/client-and-gateway-event-scripts.md) now allow security to be set on them in the form of security zone and role name combinations. ### User Management Extension Functions The [User Management component](appendix/components/admin/user-management/user-management.md) got a few new extension functions: onDeleteRole, onCreateRole, and onCreateUser. ### Schedule Management Extension Functions The [Schedule Management](appendix/components/admin/schedule-management/schedule-management.md) component got a few new extension functions: onCreateSchedule, onDeleteSchedule, onCreateHoliday, onDeleteHoliday. ## New in 7.9.3 ### Scripting Added [system.util.sendRequest()](appendix/scripting-functions/system-util/system-util-sendRequest.md) and [system.util.sendRequestAsync()](appendix/scripting-functions/system-util/system-util-sendRequestAsync.md), both of which send a message using the message handlers and wait for a return. ### Easy Chart The [X-Trace Track Mouse](appendix/components/charts/easy-chart/easy-chart.md) property has been added to the Easy Chart. This allows the X-Trace to automatically follow the mouse cursor. ## New In 7.9.2 ### Ignition Edge Introduced a new software called [Ignition Edge](getting-started/ignition-edge/ignition-edge.md). Based on the Ignition platform, Edge is scaled down to help reduce cost and is perfect for placing at the edge of the network where data collection and processing may be difficult. ### OPC Optimistic Writes Added an [OPC Optimistic Writes](tags/scan-classes/editing-scan-classes.md) setting to scan classes that will apply written values to OPC Tags immediately instead of waiting for confirmation from the plc. ### Derived Tags Added a new Tag Type called the [Derived Tag](tags/understanding-tags/types-of-tags.md#derived-tags), allowing you to refer to other Tags and use an expression on them to manipulate them into a new value. ### Scripting Added [system.gui.getCurrentDesktop()](appendix/scripting-functions/system-gui/system-gui-getCurrentDesktop.md) to return the current Desktop Handle. ### Remote Agent Upgrade EAM Agent system upgrades may now be performed from the Controller by using the [Remote Upgrade](enterprise-administration/agent-management/remote-upgrade/remote-upgrade.md) feature. ### Email Notification A [Simple One-way Email Notification](alarming/alarm-notification/notification-profile-types/simple-one-way-email-notification-profile.md) type has been added. ## New In 7.9.1 ### Tags Added a ["Trust Remote Roles"](security/security-zones/security-zones.md) option for other Gateways in the network. This allows remote users to satisfy Tag permissions as long as the remote rolename matches the source rolename. ### Components Added onDeleteUser Extension Function to the [User Management](appendix/components/admin/user-management/user-management.md) component. ### Alarming Acknowledge messages are now customizable for [SMS notification pipeline blocks](alarming/alarm-notification/alarm-notification-pipelines/pipeline-blocks/pipeline-blocks.md). Added an option to [acknowledge alarms via email using POP3](alarming/alarm-notification/notification-profile-types/email-notification-profile.md). ### Scripting Added [system.date.parse()](appendix/scripting-functions/system-date/system-date-parse.md) to convert a string into a date. ### Reporting Added the ability to [bind number and date formats](reporting/report-design/data-keys/data-keys.md#dynamic-data-keys) in Text Shape components. ## New In 7.9 ### Gateway Webpage Complete overhaul to look and feel of the [Gateway Webpage](gateway/gateway.md). There are many updates to aid troubleshooting and self-diagnosis of your system. New logger system that gives better searching and filtering options. Automatically filtered loggers on each device/connection/etc. page, and the ability drill into any item. ### Distributed Services View and interact with Tags from any Gateway in your network. This allows for many more architectures including true scale-out systems. * [Remote Tag Provider](tags/understanding-tags/understanding-tags.md): Read and write to Tags on a remote system from any Gateway in your network. * [Remote History Provider](historian/configuring-tag-historian/configuring-tag-historian.md): View Historical Tag data from anywhere. Access data from any Ignition without dealing with additional database connections. * [Remote Alarm Provider](alarming/alarm-notification/notification-profile-types/remote-gateway-notification.md): Manage your alarm notification systems in one place. Allows any alarm throughout the Gateway Network to access these Notification Profiles and Pipelines. ### Global Templates [Create templates](visualization-and-dashboards/templates/templates.md) in the Global space to give all projects on your Gateway access to those templates. ### Multi-Monitor Support The Vision modules now lets you [open multiple client frames](clients/multi-monitor-clients.md) sharing the same client resources (user credentials, Client Tags). Interact with windows in each client frame from any other frame. ### Security Zones [Restrict access](security/security-zones/security-zones.md) to various services (remote Tags, Alarms, Pipelines, etc.) based on the Gateway trying to access it. ### User Password Policies [Set password policies](security/user-sources/internal-authentication/internal-authentication.md) for your users. Enforce password length and complexity, force password updates, and restrict re-use. ### Multiple Licences [Activate multiple licences](gateway/licensing-and-activation/licensing-and-activation.md) on one Ignition Gateway. Add 3rd party modules simply, or combine licenses with ease. ### ARM Support [Install Ignition](getting-started/installing-and-upgrading/arm-install.md) on ARM processors. ### OPC Array Read/Write Write support has been added to [array Tags](tags/understanding-tags/array-and-dataset-tags.md). ### Modbus Write Optimizations Limit the size of [Modbus](opc-ua-and-device-connections/modbus/connecting-to-modbus-device.md) OPC-UA writes. ### Enable/Disable UA Connections Enable or disable UPC-UA connections through scripting calls. ### Power Table changes Power Table component now has View Dataset property and Copy Selection. ### OPC-COM Tunneller Module The OPC-COM Tunneller Module is not part of the normal release cycle. It can still be downloaded from the 7.8.5 downloads page, and that version will work just fine with Ignition 7.9.
