--- title: "Table - Indirect Tag History Binding" --- # Table - Indirect Tag History Binding > You can use indirection to configure the tag history binding to point to a set of tags based on any parameter on the screen. ## Set indirection on Tag History binding 1. Drag a **Table** (or a Power Table) from the Component Palette into your window. 2. In the Property Editor, go to the **Data** property, and click the binding icon. The Property Binding window is displayed. 3. Select the **Tag History** option. 4. From **Available Historical Tags**, find the desired historical tags by selecting and expanding the historical providers. 5. Once you have found the tag, drag it into to the right into **Selected Historical Tags**. 6. Open the **Indirection** box by clicking the plus sign next to it. 7. Double-click on one of the tags and enter a `{**1**}` in the part of the tag path that you want to create the indirection on. A new reference will appear in the indirection box. Bind the variable to the location. 8. Enter a desired start and end date in the **Start Date Binding** or **End Date Binding** text boxes. A better option is to bind these to the date properties of date components. 9. Select the appropriate **Aggregation Mode**. 10. For **Sample Size**, select the **Interval** option from the drop-down, and enter the desired interval spacing. 11. Set **Polling Mode** to **Relative** to see table update at the project's base rate. 12. Click **OK**.
