--- title: "2. Launch the Gateway" --- # 2. Launch the Gateway > The Ignition Gateway is a web server. When it is running, you access it through a web browser in just 2 steps. The default login credentials for the Gateway are: *username*: **admin** *password*: **password** 1. Figure out the IP address of the computer you installed Ignition on. If this computer is the one Ignition is installed on, then you can use **localhost** instead of the IP. 2. Open up a web browser and go to this address: **http://ipaddress:8088** and it will bring up the Gateway Homepage. If you are using localhost, it will look like this: **http://localhost:8088** ![" "](install-gateway-webpage.png) The first time you go to the Gateway Homepage, it shows you 5 common steps to help you get started. You can follow along with these steps and/or with this step-by-step walk through, they follow the same basic workflow. [Learn more about the Gateway Webpage here](gateway/gateway.md).
