--- title: "1. Download and Install Ignition" --- # 1. Download and Install Ignition > Installation is simple and can be done in under 3 minutes. Let's get started and install now. **Windows** :::note Before you install Ignition, make sure you meet the minimum system requirements * Java 8+ (server), Java 6+ (client) * Dual-Core Processor (32 or 64 bit) * 4GB RAM * 10GB free HD space Also, ensure you have Administrator privileges to run the Ignition installer. ::: 1. Go to the Inductive Automation website at www.inductiveautomation.com 2. Select **Download Ignition** in the upper right corner of the page. 3. On the Ignition Downloads page, scroll down to **System Installers** and select the **ignition-X.X.X-windows-x64-installer.exe** installer. If your computer runs on a 32-bit Windows, click the **ignition-X.X.X-windows-32-installer.exe** installer. :::note An error window is displayed if you try to install 64-bit Ignition on a 32-bit Windows system. You are allowed to install 32-bit Ignition on a 64-bit system (however, this is not recommended). ::: 4. After the installer downloads, double-click on the **.exe** executable file to start installation. The Setup window welcomes you to the Ignition Setup Wizard. ![" "](1-setup.png) 5. Click **Next.** 6. Click the **I accept the agreement** button and click **Next.** ![" "](2-license-agreement.png) The Installation Directory window is displayed. By default, Ignition is installed under your Program Files directory. This is usually a good choice. 7. Make a note of the default installation directory, **Program Files/Inductive Automation/Ignition**, accept the default Installation Directory, and click **Next.** ![" "](3-installation-directory.png) The **Installation Mode** window is displayed. 8. Select the platform you wish to install. The rest of this guide will use **Ignition** as the platform. ![" "](windowsPE.PNG) 9. Select either the **Typical** or **Custom** mode. The **Typical** installation includes Ignition with all of the HMI/SCADA modules. The only modules that are not installed by default are the MES modules. The **Custom** installation lets you control and individually select the modules that you want installed. ![" "](4-installation-mode.png) 10. Click **Next.** The Setup window is displayed. If you selected Custom mode, in the Setup window you can select the check box next to the modules you want to install as part of the Ignition installation. To see a brief description of the module, click on the module name. ![" "](5-select-components.png) 11. Click **Next.** The Setup Wizard shows Ignition is now ready to install. If you decide to change your selections, click **Back** to go back and make your changes. 12. Click **Next.** Ignition will install the selected modules. ![" "](7-installing.png) 13. After the Setup Wizard shows Ignition installation is finished, make sure that the check box for **Start Ignition now** is selected, then click **Finish.** ![" "](8-completing.png) A splash screen informs you that Ignition is starting. This may take a few minutes to finish. ![" "](image2015-1-8%2011_45_53.png) That’s it! Ignition Installation is complete and the Gateway is then launched. Your web browser opens the Gateway home page at **http: //localhost:8088** ![" "](10-Gateway-Webpage.png) Ignition installs itself as a Window Service (**Start > Control Panel > Administrative Tools > Services > Ignition Gateway**), so it starts automatically when your computer starts up. **Mac OS X** :::note Before you install Ignition, make sure you meet the minimum system requirements * Java 8+ (server), Java 6+ (client) * Dual-Core Processor (32 or 64 bit) * 4GB RAM * 10GB free HD space Also, running the installer will require **root** or **administrator** privileges ::: 1. Go to the Inductive Automation website at www.inductiveautomation.com 2. Select **Download > Current Release**. 3. On the Ignition Downloads page, scroll down to **System Installers** and select the **ignition-X.X.X-osx-installer.dmg** file. 4. After the installer downloads, double-click on the DMG. You'll see a window appear that contains a **ignition-x.x.x-osx-installer.app** file ![" "](osx_app_installer.png) 5. Double click on the APP file to start the installer. When prompted, enter your password for elevated installation privilege. The Setup window welcomes you to the Ignition Setup Wizard. ![" "](osx_setup.png) 6. Click **Next.** 7. Click the **I accept the agreement** button and click **Next.** ![" "](osx_license_agreement.png) The Installation Directory window is displayed. The default Ignition installation directory on OS X is **/usr/local/ignition**, but this is configurable. 7. Ignition will need a user name to be installed under. The user needs to already exist on the system. ![" "](osx_username.png) The **Installation Mode** window is displayed. 8. Select the platform you wish to install. The rest of this guide will use **Ignition** as the platform. 9. Select either the **Typical** or **Custom** mode. The **Typical** installation includes Ignition with all of the HMI/SCADA modules. The only modules that are not installed by default are the MES modules. The **Custom** installation lets you control and individually select the modules that you want installed. ![" "](osx_installation_mode.png) 10. Click **Next.** The Setup window is displayed. If you selected Custom mode, in the Setup window you can select the check box next to the modules you want to install as part of the Ignition installation. To see a brief description of the module, click on the module name. ![" "](osx_custom_setup.png) 11. Click **Next.** The Setup Wizard shows Ignition is now ready to install. If you decide to change your selections, click **Back** to go back and make your changes. 12. Click **Next.** Ignition will install the selected modules. 13. After the Setup Wizard shows Ignition installation is finished, make sure that the check box for **Start Ignition now** is selected, then click **Finish.** ![" "](osx_setup_complete.png) A splash screen informs you that Ignition is starting. This may take a few minutes to finish. ![" "](image2015-1-8%2011_45_53.png) That’s it! Ignition Installation is complete and the Gateway is then launched. Your web browser opens the Gateway home page at **http: //localhost:8088** ![" "](10-Gateway-Webpage.png) Ignition installs itself as a Window Service (**Start > Control Panel > Administrative Tools > Services > Ignition Gateway**), so it starts automatically when your computer starts up. **Linux** :::note Before you install Ignition, make sure you meet the minimum system requirements * Java 8+ (server), Java 6+ (client) * Dual-Core Processor (32 or 64 bit) * 4GB RAM * 10GB free HD space Also, running the installer will require **root** or **superuser** privileges. ::: 1. Go to the Inductive Automation website at [www.inductiveautomation.com] 2. Select **Download > Current Release**. 3. On the Ignition Downloads page, scroll down to System Installers and select the **ignition-X.X.X-linux-x64-installer.run** installer. If your computer runs on a 32- bit Linux, select the **ignition-X.X.Xlinux-32-installer.run**. :::note If you choose the wrong installer, an Error window is displayed letting you know the correct installer to use for your machine. ::: 4. To install programs on Linux, you must run all the commands as root. Prefix everything with sudo or first run this command to set superuser privileges: ``` sudo su ``` 5. Open a command shell and navigate to the installer executable, by running the following command from the command line: ``` sudo chmod +x ignition-x.x.x-linux-xxxinstaller.run ``` 6. Start the installer executable. :::tip The installer can run in a **graphical** mode or **text** mode: * If you are running the installer in a shell in a graphical environment, the **graphical** installer opens automatically. * If you are running the installer in a headless Linux installation or through an SSH shell, the **text** installer opens automatically. ::: To start the text installer in a graphical environment, run the following command: ``` sudo ./ignition-X.X.X-linux-xxx-installer.run --mode text ``` 7. Agree to the licensing terms. 8. Ensure the installation directory is the default directory at `/user/local/bin/ignition`: ![Graphical installer](graphical-installer.png) ![Text installer](text-installer.png) 9. Specify the user name under which Ignition is to be installed. For Ubuntu installations, the user that invoked sudo is used by default. For other Linux installations, this field is initially blank. :::note The Linux installer requires a user name to set the permissions on the folders created by the installer. This user is then able to start and stop Ignition, run the Gateway Control Utility, and the command line interfaces. The binaries in the installation folder are still owned by root and cannot be modified without root access. The selected user must already exist on the system before starting the installer. ::: 10. If the Java Installation window is displayed, type the full path to the Java executable. :::note Normally, the installer is capable of auto-detecting a Java 8 installation that has been installed through APT or some other Linux package management tool. In these cases, the installer uses that Java installation and skips this step. However, if you have installed Java by extracting the Java binaries to a folder and adding them to the system PATH, the installer is unable to find the Java binaries. You must provide the installer with a full path to the Java executable. ::: 11. Select the platform you wish to install. The rest of this guide will assume **Ignition** as the platform.
