--- title: "9. Add History to Tags" --- # 9. Add History to Tags > Storing history for your Tags is simple, and once that's done we can display it on screen in a variety of ways. Let's add history to some of our Sine Tags. ## Add History to your Tags 1. In the Designer's **Tag Browser**, select one or more tags. For example, select all the **Sine** tags in the Sine folder by holding the **Ctrl** key and clicking on several tags. 2. Right-click on the selected tags, and then select **Edit tag(s).** ![" "](edit-sine-tags.png) The Tag Editor window is displayed. Here, you can edit the tag and change the name, data type, scaling options, metadata, permissions, history, and alarming. 3. Click on **History** on the left side of **Tag Editor**. ![" "](add-history-tag-page.png) 4. Click **Yes** for the **Store history for this tag** field. This will enable all of the fields. 5. Choose a database from the **History Provider** dropdown. For example, choose **MySQL** as the database you want to log to. 6. Choose **Default** for **Historical Scanclass**. This sets the rate at which data is logged. This Default is set to 1 second which means data is logged every second. ![" "](Sine-Tag-History-10.png) 7. Click **OK**. Now look in the **Tag Browser**. To the right of each **Sine** tag that is storing history, an icon appears letting you know it is set up. ![" "](Sine-Tag-Data-11.png) If you were to look in your database, you can see all the tables and data Ignition has created for you. [Learn more about the Historian](historian/historian.md)
