--- title: "Project Backups" --- # Project Backups > ## Project Backup/Export Projects can be exported individually. Project exports only include project-specific elements, like windows, transaction groups, templates, reports, client Tags, and project scripts. They **do not** include Gateway resources, like database connections, Tag Providers, alarm pipelines, and global script items. ### Resources in a Project Export The resources listed below are included in a Project Export. Note that this Project Export is not the same as a Global Export, which is detailed later on this page. - [Windows](visualization-and-dashboards/windows/windows.md) - [Project Templates](designer/project-templates.md) - [Client Tags](tags/understanding-tags/types-of-tags.md) - [Transaction Groups](sql-bridge-transaction-groups/sql-bridge-transaction-groups.md) - [Project Properties](projects/project-properties/project-properties.md) - [Client Event Scripts](scripting/scripting-in-ignition/client-and-gateway-event-scripts.md) - [Gateway Event Scripts](scripting/scripting-in-ignition/client-and-gateway-event-scripts.md) - [Named Queries](sql-in-ignition/named-queries/named-queries.md) - [Reports](reporting/reporting.md) ### Resources in a Global Project Export An export of the Global Project will only contain resources that are listed under the **Global** section of the project browser. The resulting file may be treated like a standard Project Export in regards to importing. The following resources are included in a Global Project Export: - [Global Templates](visualization-and-dashboards/templates/templates.md) - [Alarm Pipelines](alarming/alarm-notification/alarm-notification-pipelines/alarm-notification-pipelines.md) - [Shared Scripts](scripting/scripting-in-ignition/project-and-shared-scripts.md) - [Sequential Function Charts](sequential-function-charts/sequential-function-charts.md) There are two primary ways you can export / backup a project: - **Gateway Webpage** - exports the entire project as a .proj backup file. - **In Designer using File > Export in the Menubar** - lets you export an entire project or select only the resources you want to export from your project. ### To back up a project in the Gateway Webpage Making a project backup from the Gateway webpage creates a project backup of the entire project. 1. Go to the **Configure** section of the Gateway webpage. 2. Select **System** > **Projects**. The **Projects** page is displayed and you can see your existing projects. 3. To the right of project name, click the **More** button and select **export**. This exports your project as a `.proj` backup file. By default, the `.proj` backup file is saved in your web browser's default Downloads folder. This export of the project can be [uploaded](gateway/making-backups-and-restoring/project-restore.md) to any other instance of Ignition that is running the same version or later. ![" "](project-backup-gateway-webpage.png) ### To Make a Backup in the Designer Making a project backup in the Designer lets you select an entire project or only the resources you want to backup. This example exports only selected resources. 1. In Designer, select **File** > **Export**. ![" "](making-bkups-project-export2.png) 2. An Export window will open. Check the resources from your project that you want to export, and click **Export**. ![" "](making-bkups-project-export-checkbox.png) 3. If you are exporting selected resources, Ignition will enter '**partial**' in the filename. 4. Click **Save**. ![" "](making-bkups-saving-project-export-file.png)
