--- title: "Connections - SECSGEM Equipment" --- # Connections - SECSGEM Equipment > ![Connections List with SECSGEM](Connections-secsgem-list.png) ## SECSGEM Equipment The SECSGEM Equipment page displays a list of all equipment connections, their status, as well as the number of sent requests and received messages. If any piece of equipment becomes faulted, it will show a status of "Not Connected." If you click the Details button, it opens a new page with some Connection Stats. Note: the SECSGEM Module is not standard and will be missing for most installs of Ignition. The SECSGEM Equipment Connection will only be displayed in the Status section of the Gateway webpage is when the module is installed. ### SECS/GEM Equipment Page The main SECS/GEM Equipment page lists out all equipment connections and displays the number of messages sent between them and Ignition. | Attribute | Description | |---|---| | Connections | The total number of active SECS/GEM Equipment connections. | | Aggregate Throughput | The messages per second the system is sending and receiving from all devices at that time. | | Name | The name of the equipment connection in the list. | | Sent Messages | The number of messages sent to the equipment. | | Received Messages | The number of messages received from the equipment. | | Status | The status of the equipment. | ![Connections SECSGEM Equipment Page](Connections-secsgem-equipment-page.png) ### SECS/GEM Equipment Details Clicking the Details button to the right of a piece of equipment will take you to a page that shows more detailed information for that particular piece of equipment. #### Sent Messages | Attribute | Description | |---|---| | Throughput | The messages per second the system is currently sending. | | Average | The average messages sent per second from when the equipment was first enabled. | | Total | The total messages sent. | #### Received Messages | Attribute | Description | |---|---| | Throughput | The messages per second the system is currently receiving. | | Average | The average messages received per second from when the equipment was first enabled. | | Total | The total messages received. | ![Connections SECSGEM Equipment Details](Connections-secsgem-equipment-details.png)
