--- title: "Keyboard Shortcuts" --- # Keyboard Shortcuts > ## Using Keyboard Shortcuts in the Designer You can interact with screens and more by using some of the popular keyboard shortcuts in the Designer. | Action | Description | Keyboard Shortcut | | ------------------------------- | --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- | --------------------------------------------- | | Nudge | Moves selected component(s) in the direction of the arrow key by the default nudge distance. | ![" "]() | | Alt-Nudge | Same as Nudge, but uses the "alt-nudge" distance. | ![" "]() | | Resize Right | Moves the right edge of the component left or right. Add Alt to use the alt-nudge distance. | ![" "]() | | Resize Bottom | Moves the bottom edge of the component to top or bottom. | ![" "]() | | Resize Left | Moves the left edge of the component left or right. | ![" "]() | | Resize Top | Moves the top edge of the component to top or bottom. | ![" "]() | | Move Forward/Move Backward | Moves selected component(s) in the Z-order. | ![" "]() | | Move to Front/Move to Back | Moves selected component(s) to Front or Back. | ![" "]() | | Copy-Move | Copies the component when holding Ctrl while doing a mousemove. | ![" "]() | | Orthogonal-Move | Restricts to only moving straight up, down, left, or right when holding Shift while doing a mousemove. | ![" "]() | | Selection-Move | Drags the current selection when holding Alt while dragging. | ![" "]() | | Copy-Axis-Move | Combines copy move with axis move. | ![" "]() | | Proportional Resize | Resizes a component while maintaining its aspect ratio. | ![" "]() | | On-Center Resize | Resizes the selection using the center as the anchor point. | ![" "]() | | Select All | Selects all components that are siblings of the selected component. | ![" "]() | | Select Same Type | Selects all components that are siblings of the selected component and the same component type. | ![" "]() | | Select Same Type in Window | Selects all components in a window that are the same type as the selected component. | ![" "]() | | Layout | Opens Layout Constraints to let you specify layout for the component(s). | ![" "]() | | Size & Position | Opens Size & Position to let you specify exact size and position for selected component or window. | ![" "]() | | Customizer | Opens Custom Properties to let you configure complex component properties. | ![" "]() | | Customizer 2 | Opens the second Customizer if available. | ![" "]() | | Jython | Opens Component Scripting to let you configure actions for component or window. | ![" "]() | | Security | Opens Security Settings to let you set security for Component(s) or window. | ![" "]() | | Script Modules | Opens Script Module Editor for reusable Jython functions. | ![" "]() | | Save | Saves the project. | ![" "]() | | Open | Opens the Open/Create Project to let you select a different project. | ![" "]() | | Undo | Undoes the last action. | ![" "]() | | Redo | Gets rid of the last undo action. | ![" "]() | | Copy | Copies selected component(s) or window. | ![" "]() | | Duplicate | Duplicates selected component(s) or window. | ![" "]() | | Cut | Cuts selected component(s) or window. | ![" "]() | | Paste | Pastes selected component(s) or window in clipboard. Pasted component(s) wait for position before pasting. | ![" "]() | | Immediately Paste | Places pasted component(s) at the same location where they were copied/cut. | ![" "]() | | Comment/Uncomment Lines of Code | Quickly comment or uncomment lines of a script or query in Designer. | ![" "]() | | Cancel | Cancels a pending paste operation, deselects the current row of a table, cancels dragging components onto window. | ![" "]() | | Find/Replace | Opens Find/Replace to let you Search and replace the project based on string, pattern, or regex. | ![" "]() | | Delete | Deletes the current selection. | ![" "]() | | Snap to Grid | Toggles whether or not moving and resizing components snaps to the grid. | ![" "]() | | Snap to Guides | Toggles whether or not moving and resizing components snaps to guides. | ![" "]() | | Console | Opens the Output Console. | ![" "]() | | Help | Launches the Ignition User Manual in a web browser. | ![" "]() | | Preview Mode | Toggles preview/design mode. | ![" "]() | | Rename | Renames the selected item (tag, window, transaction group, component, and so on). | ![" "]() | | Launch Staging Project | Launches the staging client from the Designer. | ![" "]() | | Launch Published Project | Launches published client from the Designer. | ![" "]() | | Update Project | Updates project to server. Receives concurrent edits from other Designers. | ![" "]() | | Zoom | Zooms in/out in the Designer. | ![" "]() | | Lasso Select | Draws a lasso and every component in the path will be selected. | ![" "]() | | Select Through | Click on a component that is beneath another component. You can do this multiple times if there are several layers of components. | ![" "]() | | Code Folding/Unfolding | Select a line of code, and this command will collapse the selection. Press again while the folded code is selected, and the code will unfold. The Script Console has a separate command for code folding. | ![" "]() |
