--- title: "Installing MySQL" --- # Installing MySQL > ## To Install the MySQL Server and Workbench 1. Go to the MySQL website at [http://dev.mysql.com/downloads/mysql/](http://dev.mysql.com/downloads/mysql/). 2. Scroll-down to **Windows (x86,64-bit), MySQL Installer MSI**. ![" "](install-mysql-step-2.png) 3. Click on the **Download** button. 4. Scroll-down to **mysql-installer-community-x.x.xx.x.msi**. :::note MySQL Installer is 32-bit, but will install both 32-bit and 64-bit binaries. ::: ![" "](install-mysql-step-4.png) 5. Click the **Download** button. 6. On the next page, click the **No thanks, just start my download**. ![" "](install-mysql-step-6.png) The **.msi** file will start downloading. 7. Click the **.msi** file to run it and to configure the installer. The **Welcome** window will be displayed. 8. Select the **Install MySQL Products** action. ![" "](install-mysql-step-8.png) 9. On the **License Agreement** page, click the **I accept the license terms** box and click **Next**. ![" "](install-mysql-step-9.png) 10. On the **Find latest products** page, click **Execute** to check for installer updates from MySQL. If you want to use the version you have, you can select the skip option. When checking is complete, click **Next**. ![" "](install-mysql-step-10.png) 11. On the **Choosing a Setup Type** page, the simplest option is to select **Developer Default** and click **Next**. The only drawback is that the install will be much larger. ![" "](install-mysql-step-11a.png) Optionally, you can select the **Custom** option and remove everything except the **MySQL Server** object. You can include the **MySQL Workbench** if you want, it is nice to have if you ever want to modify the raw structures. ![" "](install-mysql-step-11b.PNG) 12. On the **Check Requirements** page, click **Execute** to make sure all required prerequisites are met. Follow any instructions to install any missing prerequisites. Click **Next** once all prerequisites are met. ![" "](install-mysql-step-12.png) 13. On the **Installation Progress** page, click **Execute** to install all of MySQL products. The **MySQL Server** and the **MySQL Workbench** will both be installed. Once all of the products are installed click **Next**. ![" "](install-mysql-step-13.png) 14. On the **Configuration Overview** page, click **Next** to setup the configuration. 15. On the **MySQL Server Configuration** page (1/3), make sure the default **Port Number** is **3306**, keep all the defaults and click **Next**. ![" "](install-mysql-step-15.png) 16. On the next **MySQL Server Configuration** page (2/3), choose a password for the root user, type it in, and write it down so you have it for future, then click **Next**. ![" "](install-mysql-step-16.png) 17. Make sure the following two items are selected by default: - **Start the MySQL Server at System Startup** - **Standard System Account** ![" "](install-mysql-step-17.png) This installs MySQL as a Service and starts MySQL automatically each time you start your computer. 18. Click **Next**. The **Configuration Overview** page is displayed and shows the MySQL server installation is complete. ![" "](install-mysql-step-18.png) 19. Click **Next**. 20. The **Installation Complete** window is displayed and shows the check box for **Start MySQL Workbench after Setup** is selected. ![" "](install-mysql-step-20.png) 21. Click **Finish** to close the Wizard and complete the installation. The **MySQL Workbench** window is displayed. MySQL Workbench lets you to administrate the MySQL server. 22. Click on **Local instance MySQL** to connect to the newly installed MySQL server. ![" "](install-mysql-step-22.png) 23. Enter the root **password** you earlier entered into the installer and click **OK**. 24. The **Local instance MySQL** graphical user interface is displayed. ![" "](install-mysql-step-24.png) You are now connected and can see, in the Navigator, the default databases. Older versions of MySQL will start with a database named **test** where new ones may not. 25. If you want to create a new schema with a new name (like **test**), right-click in the white background of the Object Browser (next to the rest of the schemas) and select **Create Schema**. Name it and click the **Apply** button in the lower right.
