--- title: "Connecting to Oracle Express" --- # Connecting to Oracle Express > ## Overview This page details how to configure a connection to an Oracle database. Note that in some cases you may need to update your JDBC driver, so it is a good idea to consult the table of [supported databases](database-connections/database-connections.md#supported-databases-in-ignition). ### To Connect Ignition to the Oracle Express Database 1. From the Gateway, go to the **Configure** section. 2. From the menu on the left, select **Databases** > **Connections**. The **Database Connections** page will be displayed. 3. Look for the blue arrow, click on **Create new Database Connection...**. ![" "](no-db-connections.png) 4. Select the **Oracle JDBC Driver** and click **Next**. ![" "](add-oracle-jdbc-driver.png) 5. Enter the following information: Name: **Oracle** Connect URL: **jdbc:oracle:thin:@localhost:1521:XE** (**XE** is the System ID in Oracle) username: **SYSTEM** password: **oracle** (password is what you entered in during the Oracle server installation, in this example, the password is **oracle**) ![" "](new-oracle-db-connection.png) 6. Click **Create New Database Connection** at the bottom of the form. The Database Connections page is displayed showing the **Status** of your connection as **Valid**. ![" "](oracle-valid-db-connection-status.png) 7. To display the details about the status of your database connection, see the **Note** on the above window and click on the **Database Connection Status** link. ![" "](db-connection-status-oracle.png)
