--- title: "Connecting to MySQL" --- # Connecting to MySQL > ## Overview This page details how to configure a connection to a MySQL database. Note that in some cases you may need to update your JDBC driver, so it is a good idea to consult the table of [supported databases](database-connections/database-connections.md#supported-databases-in-ignition). ### To Connect Ignition to MySQL Database 1. From the Gateway, go to the **Configure** section. 2. From the menu on the left, select **Databases** > **Connections**. The Database Connections page will be displayed. 3. Look for the blue arrow, clink on **Create new Database Connection...**. ![" "](mysql-create-new-database-connection.png) 4. Select the **MySQL ConnectorJ** driver and click **Next**. ![" "](add-mysql-connectorj.png) :::note Database connections in Ignition are powered by JDBC drivers. Ignition ships with drivers for Microsoft SQL Server, MySQL, and a few others. ::: 5. On the **New Database Connection** page, enter the following information: * Name: **MySQL** (Use a meaningful name such as **MySQL**) * Connect URL: **jdbc:mysql://localhost:3306/test** (By default, MySQL creates an empty database called **test**) ![" "](new-mysql-database-connection.png) :::note MySQL uses the following **Connect URL** format: **jdbc:mysql://hostaddress:3306/database** Where **hostaddress** is the address of the machine with MySQL installed, for example: localhost, 192.168.1.1, db-server, etc. and **database** specifies the database the database schema the connection will target. It's important to understand that a MySQL server can host many database files. The connection will target one database. ::: 6. To configure the connection, enter the following information: * Username: **root** * Password: **mysql** (Password is what you entered during MySQL server installation, **mysql** is the password for this example) * Extra Connection Properties: Leave at the default value. By default, the **zeroDateTimeBehavior** parameter is defined and it is usually not necessary to add more parameters unless you are planning to store text outside of the range of 7-bit ASCII (a-z). If you are, add **useUnicode=yes;characterEncoding=utf8;** to the end of the extra connection properties, including the semi-colons. ![" "](mysql-username-password.png) 7. Click on **Create New Database Connection** at the bottom of the form. Your connection is now created and the Database Connections page is displayed showing the **Status** of your connection as **Valid**. ![" "](mysql-connection-valid.png) 8. To display the details about the status of your database connection, click the **Database Connection Status** link in the **Note** under the Database Connections list. This will display the connection status or any errors if the status is Faulted. ![" "](mysql-database-connection-status.png)
