--- title: "Connecting to Microsoft SQL Server Express" --- # Connecting to Microsoft SQL Server Express > ## Overview This page details how to configure a connection to a SQL Server database. Note that in some cases you may need to update your JDBC driver, so it is a good idea to consult the table of [supported databases](database-connections/database-connections.md#supported-databases-in-ignition). ### Connecting to Microsoft SQL Server 1. From the Gateway, go to the **Configure** section. 2. From the menu on the left, select **Databases** > **Connections**. The **Database Connections** page will be displayed. 3. Look for the orange arrow, click on **Create new Database Connection...**. 4. Select **Microsoft SQLServer JDBC Driver** and click **Next**. ![" "](create-mssql-jdbc-driver.png) The **New Database Connection** page will be displayed. 5. On the **New Database Connection** page, enter the following information: Name: **SQLServer** Connect URL: `jdbc:sqlserver://localhost\SQLEXPRESS` username: **sa** password: **sqlserver** (password is what you entered during the SQL Server installation. For this example, password is **sqlserver**) :::note We are connecting to the express edition of SQL Server using the default instance name in the **Connect URL** field. If you have the full SQL Server with default settings, replace SQLEXPRESS with MSSQLSERVER. ::: ![" "](new-mssql-database-connection.png) 6. At the bottom of the form, click on **Create New Database Connection**. Your connection is now created and the **Database Connections** page is displayed showing the **Status** of your connection as **Valid**. ![" "](valid-sql-jdbc-driver.png) 7. To display the details about the status of your database connection, see the **Note** on the above window and click on the **Database Connection Status** link. ![" "](sqlserver-db-status.png) ## Microsoft SQL Server Connection Guide This guide helps you with any difficulties you may have in getting the correct settings and parameters when connecting Ignition to Microsoft SQL Server, a popular and robust relational database. ### Multiple Instances of Database Microsoft SQL Server supports multiple instances of the database running concurrently on the same computer. Each instance has its own name and set of system and user databases that are not shared between instances. Applications, such as Ignition, can connect to each instance on a computer in much the same way they connect to databases running on different computers. By default, each instance gets assigned a dynamic TCP/IP port on startup that listens for any incoming requests. Since the port is dynamic and the application does not know what the new port is, it must connect using the instance name. So if the communication is over TCP/IP and the application knows the instance name, how does the application find which port to communicate to? The answer is the Microsoft SQL Server Browser service. The **Microsoft SQL Server Browser** program runs as a Windows service and listens for all incoming requests for resources and provides information, such as the TCP/IP port, about each instance installed on the computer. Microsoft SQL Server Browser also contributes to these two actions: browsing a list of available servers and connecting to the correct server instance. If the Microsoft SQL Server Browser service is not running, you can still connect to SQL Server if you provide the correct port number. For example, you can connect to the default instance of SQL Server with TCP/IP if it is running on port 1433. ### Check 1: Make Sure the Database has TCP/IP is Enabled Ignition connects using TCP/IP, therefore make sure your database has TCP/IP enabled. #### To check if TCP/IP is enabled 1. Open the **SQL Server Configuration Manager** from **Start** > **All Programs** > **Microsoft SQL Server Version #** > **Configuration Tools** > **SQL Server Configuration Manager** The **SQL Server Configuration Manager** window will be displayed. 2. To see all the instances setup on that machine, expand **SQL Server Network Configuration**. 3. Find the database (or instance) you plan on using. To the right, all of the protocols the database supports are shown. Find the **TCP/IP** protocol and select it. ![" "](find-tcp-ip-protocol.png) 4. Make sure the **Status** next to TCP/IP is **Enabled**. If not, double-click **TCP/IP** and choose **Yes** from the drop-down next to Enabled and click **OK**. ![" "](tcp-ip-status-enabled.png) ### Check 2: Make Sure Microsoft SQL Server Browser is Running If you ARE connecting to your database using a NAMED INSTANCE, you must make sure that the Microsoft SQL Server Browser is running. As mentioned earlier, the Microsoft SQL Server Browser translates the instance name to a TCP/IP port in order for Ignition to connect to it. #### To check if Microsoft SQL Server Browser is running Open the SQL Server Configuration Manager from Start > All Programs > Microsoft SQL Server Version # > Configuration Tools > SQL Server Configuration Manager Select the SQL Server Services section. On the right, see all of the services installed. One of the services is SQL Server Browser. Make sure this service is in fact running. If the service is not running, right-click and select Start. :::note The service could be disabled, so you may need to double-click it to enable the service before starting it up. ::: ![" "](sqlserver-server-browser-status.png) ## Different Ways of Connecting to SQL Server Now that you have ensured that TCP/IP is enables and the Microsoft SQL Server Browser is running, you can connect to Microsoft SQL Server in four different ways (all using TCP/IP communication) as follows: 1. Connect using an Instance Name and SQL Authentication 2. Connect using an Instance Name and Windows Authentication (this is the most common method) 3. Connect using a Port and SQL Authentication 4. Connect using a Port and Windows Authentication ### Scenario 1: Connect By Using an Instance Name and SQL Authentication By default, Microsoft SQL Server only allows Windows authentication since it is more secure. But because we are using SQL authentication, we must enable Microsoft SQL to allow this type of authentication. #### To enable SQL authentication 1. Open the **Microsoft SQL Server Management Studio** window from **Start** > **All Programs** > **Microsoft SQL Server Version #** > **SQL Server Management Studio** The window is displayed showing connections to your database. 2. Right-click the top-level database in the **Object Explorer** and select **Properties**. ![" "](mssql-server-management-studio-properties.png) 3. From the Server Properties window, on the left side, select **Security**. ![" "](server-properties-security.png) 4. Verify that **SQL Server and Windows Authentication** mode is selected. If not, select it and click **OK**. Now you need to restart the **SQL Server Windows** service so that this setting takes effect. 5. Open the **SQL Server Configuration Manager** at **Start** > **All Programs** > **Microsoft SQL Server Version #** > **Configuration Tools** > **SQL Server Configuration Manager**. 6. Select the **SQL Server Services** section and restart the **SQL Server (Instance Name)** item. ![" "](sqlserver-services.png) Now that Microsoft SQL Server accepts SQL authentication, we can configure Ignition. #### To Configure the database connection in Ignition 1. Go to and login to the Ignition Gateway configuration page from your webbrowser at `http://hostname:8088/main/web/config/` 2. Select **Databases** > **Connections** from the menu. 3. Click on **Create new Database Connection**. 4. Select **Microsoft SQL Server JDBC Driver** and click **Next**. 5. In the **New Database Connection** window, enter the following information: Name: **SQLServer_SQLAuth** (no spaces) Connect URL: `jdbc:sqlserver://Hostname\InstanceName` where **Hostname** is your databases IP address or hostname and **InstanceName** is your databases instance name, for example: `jdbc:sqlserver://localhost\SQLEXPRESS` `jdbc:sqlserver://10.10.1.5\MSSQLSERVER` 6. Set the username and password to a valid SQL authentication user. For example, **sa** is the default administrator account you can use. 7. To add your own user account, open the SQL Server Management Studio and expand the **Security** > **Logins** folder. You will see all the current logins including sa and you can add a new login. - To add a new login, right-click on the **Logins** folder and click **New Login...**. The **Login** window is displayed. - Choose the **SQL Server authentication** mode and type in a Login name and password. :::note You will also have to add permissions to your database by mapping db_datareader and db_datawriter to the new user in the **User Mapping** section of the Login window. If you want Ignition to be able to create tables (ie: for Tag History), you also need to give table creation access such as db_owner. ::: 8. Go back to the **New Database Connection** page in the Gateway, enter the name of your database, for example, in the **Extra Connection Properties** enter: **databaseName=test** (replace **test** with your database name, not the instance name) 9. Click **Create New Database Connection**. The Database Connection page is displayed showing the Status as **Valid** after a couple of seconds. If the connection is **Faulted**, click on the Database Connection Status link to find out why. Typically, the username/password is incorrect or the user doesn't have the right permissions. ### Scenario 2: Connect By Using Instance Name and Windows Authentication In Windows authentication mode, the username and password used to connect comes from the Ignition Windows Service logon. By default, the Ignition Windows Service is set to local system account which usually doesn't have privileges to connect. #### To set up the service to use Windows Authentication 1. Install the [Microsoft JDBC driver package](https://learn.microsoft.com/en-us/sql/connect/jdbc/microsoft-jdbc-driver-for-sql-server-support-matrix?view=sql-server-ver16#java-and-j\[…\]on-support). The exact version required depends on the version of Java your Gateway is using, and the version of the JDBC Driver Ignition is using must match the downloaded DLL file. If you have any questions regarding which version to download, reach out to our [Support](https://support.inductiveautomation.com/hc/en-us) team for guidance. 2. Extract the files to your desktop. Locate the appropriate DLL from the correct architecture folder (x86 for 32-bit JDBC and x64 for 64-bit JDBC) inside of the `enu/auth` folders in the zip file. Make sure to select the version that matches your database connector, not your computer architecture. 3. Copy the `DLL` file to the **lib** folder in your install directory. If you have the default install directory, it's in the following location: `C:\Program Files\Inductive Automation\Ignition\lib\` 4. The account used to connect will be the account that Ignition is running under in the services menu. To setup Ignition to logon using the right Windows account, open the **Services Control Panel** from **Start** > **Control Panel** > **Administrative Tools** > **Services** 5. Right-click the **Ignition** service and choose **Properties**. 6. Select the **Log On** tab. 7. Choose the **This account** radio button and enter in your Windows username and password. 8. Click **OK** to save. 9. Now restart the Ignition service to make this change take effect. Click the **Action** > **Restart** button in the menubar to restart the Ignition service (or your can stop and start from the right-click menu). #### To configure the database connection in Ignition 1. Go to and login to the Ignition Gateway configuration page from your webbrowser at `http://hostname:8088/main/web/config/ ` 2. Select **Databases** > **Connections** from the menu. 3. Click on **Create new Database Connection**. 4. Select **Microsoft SQL Server JDBC Driver** and click **Next**. 5. On the **New Database Connection** page, enter the following information: * Name: **SQLServer_WinAuth** (no spaces) * Connect URL: `jdbc:sqlserver://Hostname\InstanceName` * **Hostname** is your databases IP address or hostname and **InstanceName** is your databases instance name, for example: `jdbc:sqlserver://localhost\SQLEXPRESS` `jdbc:sqlserver://10.10.1.5\MSSQLSERVER` * username: leave blank * password: leave blank * Extra Connection Properties: **databaseName=test; integratedSecurity=true;** (replace test with your database name) 6. Click on **Create New Database Connection**. The Status should be Valid after a couple of seconds. Again, if the connection is Faulted, click the Database Connection Status link to find out why. ### Scenario 3: Connect By Using Port and SQL Authentication Connecting by using a port and SQL authentication is just like scenario 1 above except you specify a port instead of the instance name in the **New Database Connection** page. Enter the following: Connect URL: `jdbc:sqlserver://Hostname:Port` where **Hostname** is your databases IP address or hostname and **Port** is your databases TCP/IP port (SQLSERVER default port is 1433), for example: `jdbc:sqlserver://localhost:1433` `jdbc:sqlserver://10.10.1.5:1433` ### Scenario 4: Connect By Using Port and Windows Authentication Connecting by using a port and Windows authentication is just like scenario 2 above except you specify a port instead of the instance name in the New Database Connection page. Don't forget to download the `sqljdbc_auth.dll` file if you need it. Enter the following: Connect URL: `jdbc:sqlserver://Hostname:Port` where **Hostname** is your databases IP address or hostname and **Port** is your databases TCP/IP port (SQLSERVER default port is 1433), for example: `jdbc:sqlserver://localhost:1433` `jdbc:sqlserver://10.10.1.5:1433` ## Troubleshooting ### TCP/IP Communication Not Enabled SQL Server requires that you explicitly turn on TCP connectivity. To do this, use the SQL Server Configuration Manager, located in the **Start** menu under **Microsoft SQL Server** > **Configuration Tools**. Under **SQL Server Network Configuration**, select your instance, and then enable TCP/IP in the panel to the right. You need to restart the server for the change to take affect. ### Window Firewall When connecting remotely, make sure that Windows Firewall is disabled, or set up to allow the necessary ports. Normally ports 1434 and 1433 must be open for TCP traffic, but other ports may be required based on configuration. ### SQL Server Browser Process Not Running To connect to a named instance, the **SQL Server Browser** service must be running. It is occasionally disabled by default, so you need to verify that the service is not only running, but set to start automatically on bootup. The service can be found in the Windows Service Manager (**Control Panel** > **Administrative Tools** > **Services**). ### Mixed Mode Authentication Not Enabled Unless selected during setup, **mixed mode** or **SQL authentication** is not enabled by default. This mode of authentication is the u**sername/password** scheme that most users are used to. When not enabled, SQL Server only allows connections using Windows Authentication. Due to the ease of using SQL Authentication over Windows Authentication, we recommend enabling this option and defining a user account for Ignition. To enable this, open the SQL Server Management Studio and connect to the server. Right click on the instance and select **Properties**. Under **Security**, select **SQL Sever and Windows Authentication mode**.
