--- title: "system.util.translate" description: "This function allows you to retrieve the global translation of a term from the translation database using the current locale." --- # system.util.translate > This function allows you to retrieve the global translation of a term from the translation database using the current locale. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax - term Parameter only `system.util.translate(term)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`term` |The term to look up.| ### Returns **String** - The translated term. ### Scope Client ## Syntax - term, locale, and strict Parameters `system.util.translate(term, locale, strict)` - Parameters - String `term` - The term to look up. - String `locale` - Boolean `strict` - Returns - String - The translated term. - Scope - Client ## Code Examples ```python title="Example #1" # This script will take a term written into a Text Field component, translate it using the translation database, and then write it back to the same Text Field. # it uses the current locale since none is specified. text = event.source.parent.getComponent('Text Field').text translation = system.util.translate(text) event.source.parent.getComponent('Text Field').text = translation ```
