--- title: "system.util.setConnectionMode" description: "Sets the connection mode for the client session." --- # system.util.setConnectionMode > Sets the connection mode for the client session. This function is used in **Python Scripting**. ## Description Sets the connection mode for the client session. Normally a client runs in mode 3, which is read-write. You may wish to change this to mode 2, which is read-only, which will only allow reading and subscribing to tags, and running SELECT queries. Tag writes and INSERT/UPDATE/DELETE queries will not function. You can also set the connection mode to mode 1, which is disconnected, all tag and query features will not work. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.setConnectionMode(mode)` ### Parameters |Type|Parameter|Description| |--|--|--| |int |`mode`| The new connection mode. 1 = Disconnected, 2 = Read-only, 3 = Read/Write.| ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" # This example, which could go in a project's startup script, would check the current username and set the connection mode to read-only if it is the "guest" user. username = system.security.getUsername() if "guest" == username.lower(): # Set "guest" user to read-only mode system.util.setConnectionMode(2) else: system.util.setConnectionMode(3) ```
