--- title: "system.util.queryAuditLog" description: "Queries an audit profile for audit history." --- # system.util.queryAuditLog > Queries an audit profile for audit history. This function is used in **Python Scripting**. ## Description Queries an audit profile for audit history. Returns the results as a dataset. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.queryAuditLog(auditProfileName, startDate, endDate, actorFilter, actionFilter, targetFilter, valueFilter, systemFilter, contextFilter)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `auditProfileName`| The name of the audit profile to pull the history from.| |Date| `startDate` | The earliest audit event to return. If omitted, the current time - 8 hours will be used.| |Date| `endDate`|The latest audit event to return. If omitted, the current time will be used.| |String| `actorFilter` |A filter string used to restrict the results by actor.| |String| `actionFilter` | A filter string used to restrict the results by action.| |String| `targetFilter`| A filter string used to restrict the results by target.| |String| `valueFilter`| A filter string used to restrict the results by value.| |String| `systemFilter` | A filter string used to restrict the results by system.| |Integer| `contextFilter` | A bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client.| ### Returns **Dataset** - A dataset with the audit events from the specified profile that match the filter arguments. ### Scope Client ## Code Examples ```python title="Example #1" # This script queries an audit log, checks to see if a user john made any tag writes in the last 8 hours # (since the startDate parameter is omitted), and writes the results to a table. data = system.util.queryAuditLog(auditProfileName='AuditLog', actorFilter='john', actionFilter='tag write') event.source.parent.getComponent("Table").data = data ```
