--- title: "system.util.jsonDecode" description: "Takes a json String and converts it into a Python object such as a list or a dict." --- # system.util.jsonDecode > Takes a json String and converts it into a Python object such as a list or a dict. This function is used in **Python Scripting**. ## Description Takes a json String and converts it into a Python object such as a list or a dict. If the input is not valid json, a string is returned. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.jsonDecode(jsonString)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `jsonString` | The JSON string to decode into a Python object.| ### Returns **PyObject** - The decoded Python object. ### Scope All ## Code Examples ```python title="Example #1" # The following example reads in a JSON string, and converts the string to a Python object. # The example attempts to read the JSON string from a text file, but this could easily be modified to read data from a web server. # Read the JSON string jsonString = system.file.readFileAsString("C:\tmp\\json.txt") # Decode the JSON string and store the results into a variable obj = system.util.jsonDecode(jsonString) # Do something with the results. The code below prints the datatype of the results to the console. print type(obj) ```
