--- title: "system.util.getSystemFlags" description: "Returns an integer that represents a bit field containing information about the currently running system." --- # system.util.getSystemFlags > Returns an integer that represents a bit field containing information about the currently running system. This function is used in **Python Scripting**. ## Description Returns an integer that represents a bit field containing information about the currently running system. Each bit corresponds to a specific flag as defined in the bitmask below. The integer return will be a total of all of the bits that are currently active. See the example for tips on how to extract the information in this bit field. Note that the tag `[System]Client/System/SystemFlags` contains the same value. | Flag | Flag Description | Bit Value | |---|---|---| | Designer Flag | Set if running in the Designer. | 1 | | Preview Flag | Set if running in the Designer, and the Designer is in preview mode. | 2 | | Client Flag | Set if running as a Client. | 4 | | Webstart Flag | Set if running as a Client in Web Start mode. | 8 | | Applet Flag | Set if running as a Client in Applet mode. | 16 | | Fullscreen Flag | Set if running as a Client in full screen mode. | 32 | | SSL Flag | Set if communication to the Gateway is encrypted with SSL. | 64 | | Mobile Flag | Set if currently running a mobile-launched client. | 128 | | Staging Flag | Set if running a staging client. | 256 | ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.getSystemFlags()` ### Parameters None ### Returns **int** - An total of all the bits that are currently active. A full screen client launched from the gateway webpage with no SSL will have a value of 44 (Fullscreen flag + Webstart Flag + Client Flag). ### Scope Client ## Code Examples ```python title="Example #1" # The first part of the script will take the integer representing the system flags, convert it to bits, and place it in a list and then print it out. # The second part of the script will take the list of bits, and place it in a table showing what each of the bits represent. myList = [] flags = system.util.getSystemFlags() for i in range(8,-1,-1): myList.insert(0, flags >> i & 1) print myList headers = ["Designer Flag", "Preview Flag", "Client Flag", "Webstart Flag", "Applet Flag", "Fullscreen Flag", "SSL Flag", "Mobile Flag", "Staging Flag"] data = system.dataset.toDataSet(headers, [myList]) table = event.source.parent.getComponent("Table") table.data = data ```
