--- title: "system.util.exit" description: "Exits the running client, as long as the shutdown intercept script doesn't cancel the shutdown event." --- # system.util.exit > Exits the running client, as long as the shutdown intercept script doesn't cancel the shutdown event. This function is used in **Python Scripting**. ## Description Exits the running client, as long as the shutdown intercept script doesn't cancel the shutdown event. Set force to true to not give the shutdown intercept script a chance to cancel the exit. Note that this will quit the Client completely. you can use system.security.logout() to return to the login screen. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.exit([force])` ### Parameters |Type|Parameter|Description| |--|--|--| |boolean| `force`|If true (1), the shutdown-intercept script will be skipped. Default is false (0). [optional]| ### Returns Nothing ### Scope Client ## Code Examples ```python title="Example #1" # This code would exit the client after confirming with the user. if system.gui.confirm("Are you sure you want to exit?"): system.util.exit() ```
