--- title: "system.user.removeRole" description: "Removes a role from the specified user source." --- # system.user.removeRole > Removes a role from the specified user source. This function is used in **Python Scripting**. ## Description Removes a role from the specified user source. When altering the Gateway System User Source, the [Allow User Admin](gateway\gateway-settings\gateway-setup.md) setting must be enabled. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.removeRole(userSource, role)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The user source in which the role is found. Blank will use the default user source. String| `role` | The role to remove. The role must exist. ### Returns **UIResponse** - An object with lists of warnings, errors, and info about the success or failure of the deletion. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # Removes the role "User" in the user source "MyUserSource". system.user.removeRole("MyUserSource", "User") ```
