--- title: "system.user.removeHoliday" description: "Allows a holiday to be deleted." --- # system.user.removeHoliday > Allows a holiday to be deleted. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.removeHoliday(holidayName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `holidayName` | The name of the holiday to delete. Name is case-sensitive. ### Returns **UIResponse** - An object with lists of warnings, errors, and info about the success or failure of the deletion. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" def printResponse(responseList): if len(responseList) > 0: for response in responseList: print "", response else: print " None" holidayName = "Labor Day" response = system.user.removeHoliday(holidayName) warnings = response.getWarns() print "Warnings are:" printResponse(warnings) errors = response.getErrors() print "Errors are:" printResponse(errors) infos = response.getInfos() print "Infos are:" printResponse(infos) ``` ```python title="Example #1 Output" Warnings are: None Errors are: None Infos are: Holiday "Labor Day" deleted. ```
