--- title: "system.user.getSchedule" description: "Returns a specific schedule." --- # system.user.getSchedule > Returns a specific schedule. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.user.getSchedule(scheduleNames)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `scheduleName` | The name of the schedule to return. Case-sensitive ### Returns **AbstractScheduleModel** - The schedule, which can be a BasicSchedule, CompositeSchedule, or another type registered by a module, or None if not found. Once the schedule is returned, functions of the resulting object are used to get various information from that schedule. Which functions are available depend on the type of schedule returned. See examples in the SDK documentation for an [abstract schedule](https://files.inductiveautomation.com/sdk/javadoc/ignition79/790-beta1/com/inductiveautomation/ignition/common/user/schedule/AbstractScheduleModel.html), [basic schedule](https://files.inductiveautomation.com/sdk/javadoc/ignition79/790-beta1/com/inductiveautomation/ignition/common/user/schedule/BasicScheduleModel.html), or [composite schedule](https://files.inductiveautomation.com/sdk/javadoc/ignition79/790-beta1/com/inductiveautomation/ignition/common/user/schedule/CompositeScheduleModel.html). ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example will get a schedule and print info about it: # This function handles recursive printing of the different schedule types. Modules can register more types than listed here. def printScheduleInfo(aSchedule): if aSchedule.getType() == "basic schedule": print "Basic schedule type: ",aSchedule.getName(), aSchedule.getDescription(), aSchedule.isAllDays(), aSchedule.isObserveHolidays() elif aSchedule.getType() == "composite schedule": compositePieces = aSchedule.getModels() print "Composite schedule type:",aSchedule.getName(), aSchedule.getDescription(), " which is made up of..." for piece in compositePieces: printScheduleInfo(piece) else: print "Other schedule type: ", aSchedule.getName(), aSchedule.getDescription(), aSchedule.getType(), aSchedule.isObserveHolidays() # The main function scheduleName = "MySchedule" schedule = system.user.getSchedule(scheduleName) if schedule == None: print "Schedule", scheduleName, "was not found" else: printScheduleInfo(schedule) ``` ```python title="Example #1 Output" Basic schedule type: MySchedule A description False True ```
