--- title: "system.user.getHoliday" description: "Returns a specific holiday." --- # system.user.getHoliday > Returns a specific holiday. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.user.getHoliday(holidayName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `holidayName` | The name of the holiday to return. Case-sensitive ### Returns **HolidayModel** - The holiday, or None if not found. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example will get a holiday and print info about it holidayName = "Labor Day" holiday = system.user.getHoliday(holidayName) if holiday == None: print holidayName, "not found" else: print holiday.getName(), holiday.getDate(), holiday.isRepeatAnually() ``` ```python title="Example #1 Output" Labor Day 2015-09-07 00:00:00.0 False ```
