--- title: "system.user.editRole" description: "Renames a role in the specified user source." --- # system.user.editRole > Renames a role in the specified user source. This function is used in **Python Scripting**. ## Description Renames a role in the specified user source. When altering the Gateway System User Source, the [Allow User Admin](gateway\gateway-settings\gateway-setup.md) setting must be enabled. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.editRole(userSource, oldName, newName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The user source in which the role is found. Blank will use the default user source. String| `oldName` | The role to edit. Role must not be blank and must exist. String| `newName` | The new name for the role. Must not be blank. ### Returns **UIResponse** - an object with lists of warnings, errors, and info about the success or failure of the edit. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example edits the role "Operator" in the user source "MyUserSource" and edits it to the role "User". system.user.editRole("MyUserSource", "Operator", "User") ```
