--- title: "system.user.addSchedule" description: "Adds a schedule." --- # system.user.addSchedule > Adds a schedule. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.addSchedule(schedule)` ### Parameters Type | Parameter | Description ------- | ------- | ------ | AbstractScheduleModel | `schedule` | The schedule to add. | ### Returns **UIResponse** - an object with lists of warnings, errors, and info about the success or failure of the add. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example tries to add the schedule NewSchedule based on an existing schedule MySchedule, and prints the results of the action. # This function prints the response received def printResponse(responseList): if len(responseList) > 0: for response in responseList: print "", response else: print " None" # The main function mySchedule = system.user.getSchedule("Always") if mySchedule != None and mySchedule.getType() == "basic schedule": mySchedule.setObserveHolidays(False) mySchedule.setName("NewSchedule") response = system.user.addSchedule(mySchedule) warnings = response.getWarns() print "Warnings are:" printResponse(warnings) errors = response.getErrors() print "Errors are:" printResponse(errors) infos = response.getInfos() print "Infos are:" printResponse(infos) ``` ```python title="Example #1 Output" Warnings are: None Errors are: None Infos are: New schedule "NewSchedule" added. ```
