--- title: "system.user.addHoliday" description: "Adds a holiday." --- # system.user.addHoliday > Adds a holiday. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.addHoliday(holiday)` ### Parameters Type | Parameter | Description ------- | ------- | ------ HolidayModel| `holiday` | The holiday to add. | ### Returns **UIResponse** - an object with lists of warnings, errors, and info about the success or failure of the add. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example adds a holiday def printResponse(responseList): if len(responseList) > 0: for response in responseList: print "", response else: print " None" from com.inductiveautomation.ignition.common.user.schedule import HolidayModel from java.util import Date holidayName = "Groundhog Day" d = Date(2016 - 1900, 2, 2) # java dates start in 1900 repeatAnnually = False myHoliday = HolidayModel(holidayName, d, repeatAnnually) response = system.user.addHoliday(myHoliday) warnings = response.getWarns() print "Warnings are:" printResponse(warnings) errors = response.getErrors() print "Errors are:" printResponse(errors) infos = response.getInfos() print "Infos are:" printResponse(infos) ``` ```python title="Example #1 Output" Warnings are: None Errors are: None Infos are: New holiday "Groundhog Day" added. ```
