--- title: "system.twilio.getPhoneNumbersDataset" description: "Returns a list of outgoing phone numbers for a Twilio account as a single-column Dataset." --- # system.twilio.getPhoneNumbersDataset > Returns a list of outgoing phone numbers for a Twilio account as a single-column Dataset. This function is used in **Python Scripting**. ## Description Returns a list of outgoing phone numbers for a Twilio account as a single-column Dataset. Note that these numbers are supplied by Twilio, and are not defined on a user in Ignition. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.twilio.getPhoneNumbersDataset(accountName)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `accountName` | The Twilio account to retrieve phone numbers for. | ### Returns **Dataset** - A list of phone numbers for the given Twilio account as a single-column Dataset. ### Scope All ## Code Examples ```python title="Example #1" # Retrieves a list of phone numbers associated with a twilio account and then passes the resulting list to a Table component's Data property. # Checks against a Twilio Profile configured on the gateway by the name of "Twilio Account" # Call system.twilio.getPhoneNumbers() and store the returned list into a variable twilioNumbers = system.twilio.getPhoneNumbersDataset("Twilio Account") # Pass the dataset to a Table component. The Table is located in the same container as the # component calling this script event.source.parent.getComponent('Table').data = twilioNumbers ```
