--- title: "system.tag.removeTags" description: "Removes multiple tags from Ignition with a single call." --- # system.tag.removeTags > Removes multiple tags from Ignition with a single call. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.removeTags(tagPaths)` ### Parameters | Type | Parameter | Description | |---|---|---| | String[] | `tagPaths` | An array of the paths to the tags you want to remove. **Note**: You can specify the tag provider name in square brackets at the beginning of the parentPath string. Example: `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. An empty path ( '' ) will remove all tags. | ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" system.tag.removeTags(["Tag1", "Tag2"]) ```
