--- title: "system.tag.readAll" description: "Reads the values of each tag in the tag path list." --- # system.tag.readAll > Reads the values of each tag in the tag path list. This function is used in **Python Scripting**. ## Description Reads the values of each tag in the tag path list. Returns a sequence of qualified value objects. You can read the value, quality, and timestamp from each object in the return sequence. Reading in bulk like this is more efficient than calling [read()](appendix\scripting-functions\system-tag\system-tag-read.md) many times. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.tag.readAll(tagPaths)` ### Parameters | Type | Parameter | Description | |---|---|---| | String[] | `tagPaths` | A sequence of tag paths to read from. | ### Returns **QualifiedValue[]** - A sequence of qualified values corresponding to each tag path given. Each qualified value will have three sub-members: value, quality, and timestamp. ### Scope All ## Code Examples ```python title="Example #1" # This example would read 5 tags at once and print each of their values tags = ["Tags/T1", "Tags/T2", "Tags/T3", "Tags/T4", "Tags/T5"] values = system.tag.readAll(tags) for x in range(len(tags)): print "%s = %s" % (tags[x], values[x]) ```
