--- title: "system.tag.read" description: "Reads the value of the tag at the given tag path." --- # system.tag.read > Reads the value of the tag at the given tag path. This function is used in **Python Scripting**. ## Description Reads the value of the tag at the given tag path. Returns a qualified value object. You can read the value, quality, and timestamp from this object. If the tag path does not specify a tag property, then the Value property is assumed. You can also read the value of tag attributes by appending the attribute to the tagPath parameter. See the [Tag Properties](tags\understanding-tags\tag-properties.md) page for a list of available attributes. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.tag.read(tagPath)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `tagPath` | Reads from the given tag path. If no property is specified in the path, the Value property is assumed. | ### Returns **QualifiedValue** - A qualified value. This object has three sub-members: value, quality, and timestamp. ### Scope All ## Code Examples ```python title="Example #1" # This example would read a value and display it in a message box. qv = system.tag.read("[default]EastSection/ValveG/HOA_bit") system.gui.messageBox("The value is %d" % qv.value) ``` ```python title="Example #2" # This example would check the quality of a tag value, and write it to the database if the quality is good qv = system.tag.read("[default]EastSection/ValveG/HOA_bit") if qv.quality.isGood(): system.db.runPrepQuery("INSERT INTO VALVE_TABLE (HOA) VALUES (?)", [qv.value]) ``` ```python title="Example #3" # This example would check the value of the EngHigh attribute on the tag qv = system.tag.read("[default]EastSection/ValveG/HOA_bit.EngHigh") system.gui.messageBox("The EngHigh value is %d" % qv.value) ```
