--- title: "system.tag.queryTagDensity" description: "Queries the Tag history system for information about the density of data." --- # system.tag.queryTagDensity > Queries the Tag history system for information about the density of data. This function is used in **Python Scripting**. ## Description Queries the Tag history system for information about the density of data. In other words, how much data is available for a given time span. This function is called with a list of Tag paths, and a start and end date. The result set is a two column dataset specifying the timestamp, and a relative weight. Each row is valid from the given time until the next row. Tags are assigned a 1 or a 0 if they are present or not. All values are then multiplied together to get a decimal based percentage for the density. Thus, for four Tag paths passed in, if three Tags were present during the span, the result would be 0.75. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.tag.queryTagDensity(paths, startDate, endDate)` ### Parameters | Type | Parameter | Description | |---|---|---| | PySequence | `paths` | An array of Tag paths (strings) to query. | | Date | `startDate` | The start of the range to query. | | Date | `endDate` | The end of the range to query. | ### Returns **Dataset** - A 2-column dataset consisting of a timestamp and a weight. Each row is valid until the next row. ### Scope All ## Code Examples ```python title="Example #1" # Will grab the density of a tag and print it out to the console. density = system.tag.queryTagDensity( ['[default]myTag'], system.date.addHours(system.date.now(), -24), system.date.now()) density = system.dataset.toPyDataSet(density) for row in density: print row[0], row[1] ``` ```python title="Example #2" # Create a list of times going back in time at day increments. # This forces density readouts at each day, even if two days had the same density now = system.date.now() times = [system.date.addDays(now, -1), system.date.addDays(now, -2), system.date.addDays(now, -3), system.date.addDays(now, -4), system.date.addDays(now, -5), system.date.addDays(now, -6)] # Create start and end date variables, as well as a variable that holds each history density. startDate = now endDate = now list = [] # Loop through the list of times for time in times: # Set the new end date to whatever the start date was previously # and the new start date to the next time in the list. endDate = startDate startDate = time # Query Tag Density using a list of Tagpaths with the startDate and endDate values. density = system.tag.queryTagDensity( ['[default]tag1', '[default]tag2', '[default]tag3', '[default]tag4', '[default]tag5'], startDate, endDate) # Add each row of the returned dataset to a list of rows. density = system.dataset.toPyDataSet(density) for row in density: list.append([row[0], row[1]]) # Place the results in a table. event.source.parent.getComponent('Table').data = system.dataset.toDataSet(['Times', 'Density Percentages'], list) ``` ```python title="Example #3" # Create a list of times going back in time at day increments. # This forces density readouts at each day, even if two days had the same density. # This differs from the previous example in that it uses the new system.dataset.appendDataset function, which is only available in 7.9.7. now = system.date.now() times = [system.date.addDays(now, -1), system.date.addDays(now, -2), system.date.addDays(now, -3), system.date.addDays(now, -4), system.date.addDays(now, -5), system.date.addDays(now, -6)] # Create start and end date variables. startDate = now endDate = now # Loop through the list of times. for time in times: # Set the new end date to whatever the start date was previously # and the new start date to the next time in the list. endDate = startDate startDate = time # Query Tag Density using a list of Tagpaths with the startDate and endDate values. density = system.tag.queryTagDensity( ['[default]EquipmentFour', '[default]Ramp/Ramp6', '[default]Ramp/Ramp7', '[default]Ramp/Ramp8', '[default]Ramp/Ramp9'], startDate, endDate) if endDate == now: densities = density else: densities = system.dataset.appendDataset(densities, density) # Place the results in a table. event.source.parent.getComponent('Table').data = densities ```
