--- title: "system.tag.loadFromFile" description: "This function locates an exported tag file and loads the tags into the specified tag provider." --- # system.tag.loadFromFile > This function locates an exported tag file and loads the tags into the specified tag provider. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.loadFromFile(filePath, provider, mode)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `filePath`| The path of the tag file to import from. | | String | `provider`| The name of the provider to import to. | | Integer | `mode` | Dictates what happens if the tag already exists. 0 = overwrite, 1 = ignore. | ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" # The following example loads a file named 'tags.xml' located at C:\ # The backslash character is an escape character in python, so we have to use it twice for the filePath variable # Create variables to pass into the function filePath = 'C:\\tags.xml' provider = 'default' # Load the file system.tag.loadFromFile(filePath,provider,0) ```
