--- title: "system.tag.getAlarmStates" description: "Returns an array of alarm definitions for a specific tag." --- # system.tag.getAlarmStates > Returns an array of alarm definitions for a specific tag. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.tag.getAlarmStates(tagPath)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `tagPath` | The full path to the tag. **Note**: you can specify the tag provider name in square brackets at the beginning of the parentPath string. Example: `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. | ### Returns **TagAlarmDefinition[]** - An array of TagAlarmDefinition. ### Scope All :::note The properties on the alarm definitions returned by this function do not list what are considered "default" properties; calling getAlarmProperties on an alarm with a Low priority will not return the priority property of the alarm, but if the priority is changed to Medium, then the priority property would be returned. See the [Tag Properties](tags\understanding-tags\tag-properties.md) page for a full list of properties. ::: ## Code Examples ```python title="Example #1" # Get the alarm configuration for a tag. The prop.type represents whether the # value is static, bound to an expression, or bound to a UDT parameter tagDefs = system.tag.getAlarmStates("TagAlarm") for tagDef in tagDefs: print tagDef.alarm for prop in tagDef.getAlarmProperties(): print prop.property, prop.type, prop.value ```
