--- title: "system.tag.editTags" description: "Edit multiple existing Tags in Ignition with a single call." --- # system.tag.editTags > Edit multiple existing Tags in Ignition with a single call. This function is used in **Python Scripting**. ## Description Edit multiple existing Tags in Ignition with a single call. This will not work on Client Tags, because there is a Client Provider for each project. This can now be used to edit members of a nested UDT instance. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.editTags(tagPaths, attributes, parameters, accessRights, overrides, alarmList, alarmConfig[, provider][, json])` ### Parameters | Type | Parameter | Description | |---|---|---| | String[] | `tagPaths` | The full path to the Tag you want to edit. For members of UDT instances, the tagPath will be the path to the UDT instance, with the overrides parameter listing out the member Tags to edit. **Note**: You can specify the tag provider name in square brackets at the beginning of the parentPath string. For example, `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. | | PyDictionary | `attributes` | The Tag's configuration attributes. | | PyDictionary | `parameters` | The parameters for a UDT instance Tag. | | String | `accessRights` | The access rights for a Tag. Possible values are Read_Only, Read_Write, and Custom. | | PyDictionary | `overrides` | All of the overrides for a UDT instance Tag. | | String | `alarmList` | List of legacy alarms for the Tag. The legacy alarm system was retired in 7.6.0, so the alarmConfig parameter should be utilized on newer versions. | | PyDictionary | `alarmConfig` | The alarm configuration for the Tag. | | String | `provider` | The name of the Tag provider, used in conjunction with the JSON argument. The default value is the default Tag provider. Optional | | String | `json` | The properties to edit on Tags, represented as a JSON object. When using this, it acts as a replacement for other parameters. Optional. | ### Returns Nothing ### Scope All ## Code Examples There are no examples associated with this scripting function.
